주요 콘텐츠로 건너뛰기
How to Turn a Loop - Eye Pin Technique
필요한 것
  1. How to Turn a Loop - Eye Pin Technique, Thread and Bend: 1 단계, 이미지 1개 중 1개
    • Thread a bead onto your eye pin.
    • Using your chain nose pliers, make a 90 degree bend just above your bead.
  2. How to Turn a Loop - Eye Pin Technique, Remove Excess Pin Tail: 2 단계, 이미지 1개 중 1개
    • Use side cutters to cut the wire, leaving a tail that's about one third of an inch long.
  3. How to Turn a Loop - Eye Pin Technique, Turn the Loop: 3 단계, 이미지 1개 중 1개
    • Position your round nose pliers at the end of the tail, making sure the tail faces away from your body. Wrap the wire towards you to create a loop.
  4. How to Turn a Loop - Eye Pin Technique, Align Loops: 4 단계, 이미지 1개 중 1개
    • When making a link like this you'll want both loops to face the same direction. To do this, grip each loop with a pair of chain nose pliers and just twist until your loops are where you want them.
  5. How to Turn a Loop - Eye Pin Technique, Opening and Closing the Loop: 5 단계, 이미지 1개 중 1개
    • To open and close the loop, you can use chain nose pliers and gently twist it open from side to side.
결론
Practicing these steps will help you to get the loop tight against the bead, and the loop size consistent.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Shaun Harrington
회원 가입일: 11/25/17
206 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 42
전체 시간: 2,107
