주요 콘텐츠로 건너뛰기
How to Unclog Epson Workforce 2760 Ink Heads
필요한 것
  1. How to Unclog Epson Workforce 2760 Ink Heads, How to Unclog Epson Workforce 2760 Ink Heads: 1 단계, 이미지 3개 중 1개 How to Unclog Epson Workforce 2760 Ink Heads, How to Unclog Epson Workforce 2760 Ink Heads: 1 단계, 이미지 3개 중 2개 How to Unclog Epson Workforce 2760 Ink Heads, How to Unclog Epson Workforce 2760 Ink Heads: 1 단계, 이미지 3개 중 3개
    • In the "Settings" menu, set the printer cartridges to "Replace ink cartridges."
  2. How to Unclog Epson Workforce 2760 Ink Heads: 2 단계, 이미지 3개 중 1개 How to Unclog Epson Workforce 2760 Ink Heads: 2 단계, 이미지 3개 중 2개 How to Unclog Epson Workforce 2760 Ink Heads: 2 단계, 이미지 3개 중 3개
    • Move the cartridge to the side.
    • Place a towel underneath.
  3. How to Unclog Epson Workforce 2760 Ink Heads: 3 단계, 이미지 2개 중 1개 How to Unclog Epson Workforce 2760 Ink Heads: 3 단계, 이미지 2개 중 2개
    • Place the cleaning solution of 100 mL in a cup of hot boiling water, with the cap off to avoid air pressure that can damage the solution.
  4. How to Unclog Epson Workforce 2760 Ink Heads: 4 단계, 이미지 3개 중 1개 How to Unclog Epson Workforce 2760 Ink Heads: 4 단계, 이미지 3개 중 2개 How to Unclog Epson Workforce 2760 Ink Heads: 4 단계, 이미지 3개 중 3개
    • Pull 5 mL of the hot solution using the syringe.
    • Apply the solution to the black printer head first.
    • After applying the solution, wait one hour for the solution to break down the dried ink.
  5. How to Unclog Epson Workforce 2760 Ink Heads: 5 단계, 이미지 3개 중 1개 How to Unclog Epson Workforce 2760 Ink Heads: 5 단계, 이미지 3개 중 2개 How to Unclog Epson Workforce 2760 Ink Heads: 5 단계, 이미지 3개 중 3개
    • After one hour, repeat steps one through four on the other ink heads.
    • Move the ink slot back into place, and insert the new ink cartridges.
    • Under "Settings," finish replacing ink cartridges process.
    • Print a "test page" and if the results shown on image three appear, the printer heads are successfully unclogged.
결승점
작성자
1다른 기여자 명과 함께
Cristian Rodriguez
회원 가입일: 10/26/22
253 평판
안내서 1개를 작성함
CSU Los Angeles, Team 1-1, Briggs Fall 2023 CSU Los Angeles, Team 1-1, Briggs Fall 2023 회원
CSULA-BRIGGS-F23S1G1
6 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 16
지난 30일: 62
전체 시간: 681
