주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Unclog a Feeding Tube
의료 장비
iFixit과 이 수리 안내서는 의료 기기 제조업체가 보증하지 않으며 제휴 관계가 없습니다.
필요한 것
    1. How to Unclog a Feeding Tube, How to Unclog a Feeding Tube: 1 단계, 이미지 1개 중 1개
      • Test your tube. Use a 35ml plunger to test your tube, just to confirm it is clogged.
      • Exert a decent amount of force.
      댓글 쓰기
    2. How to Unclog a Feeding Tube: 2 단계, 이미지 1개 중 1개
      • Massage the tube. Roll the tubing in between your fingers and “massage” it.
      • The clog may be in the external tubing and doing so may break it up.
      댓글 쓰기
    3. How to Unclog a Feeding Tube: 3 단계, 이미지 1개 중 1개
      • Switch to a smaller plunger. Start using a 10ml plunger.
      • The smaller the plunger, the more pressure is exerted.
      댓글 쓰기
    4. How to Unclog a Feeding Tube: 4 단계, 이미지 1개 중 1개
      • Flush hot water. Fill your 10ml plunger (and extension tubing, if applicable) with hot water. As hot as you can safely tolerate. Use this to flush your tube.
      댓글 쓰기
    5. How to Unclog a Feeding Tube: 5 단계, 이미지 1개 중 1개
      • Pulsate. Pulsate the 10ml plunger back and forth, in quick motion. This helps to dismantle the clog.
      댓글 쓰기
    6. How to Unclog a Feeding Tube: 6 단계, 이미지 1개 중 1개
      • Flush a combination of hot water and meat tenderizer. If your tube is still clogged, fill your 10ml plunger (and extension tubing, if applicable) with a combination of hot water and meat tenderizer.
      • The tenderizer is known to break up clogs.
      댓글 쓰기
    7. How to Unclog a Feeding Tube: 7 단계, 이미지 1개 중 1개
      • Pulsate. Pulsate the 10ml plunger once again, in a quick motion.
      댓글 쓰기
    8. How to Unclog a Feeding Tube: 8 단계, 이미지 1개 중 1개
      • Flush Coca-Cola. If your tube is still clogged, fill your 10ml plunger (and extension tubing, if applicable) with Coca-Cola. Flush your tube.
      • Regular coke is the best for breaking up clogs due to its carbonation levels.
      댓글 쓰기
    9. How to Unclog a Feeding Tube: 9 단계, 이미지 1개 중 1개
      • Pulsate, then let Coca-Cola sit. Pulsate the 10ml plunger once again, in a quick motion. If the clog persists, allow the Coke to sit in your tube.
      • You may leave the Coke in your tube for up to one hour.
      댓글 쓰기
    10. How to Unclog a Feeding Tube: 10 단계, 이미지 1개 중 1개
      • Test your feeding tube. It should flush easily.
      댓글 쓰기
결론
The hope is to successfully unclog the feeding tube at home. Of course, always contact your health care physician in times of concern.
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jaquie Beckwith
회원 가입일: 01/23/18
346 평판
안내서 1개를 작성함
팀
4가이드 댓글
That is a very good, clear procedure to follow. Those steps are essentially what they might trying the ER. If these steps don't work, the tube probably needs to be replaced.
Sue S.S. - 답글 공유
This is so clear and helpful. There’s so little available for us tube feeders and this is a great. The Coke tip is fab. You can also use lemonade or any carbonated drink. The main thing to do is not panic, take your time and once the tube is clear , flush well with water.
Michelle - 답글 공유
I have tried time and time again to unclog my tupe unsuslectfully.hl
Have been told NOT TO USE COKE
Gerald Lacey - 답글 공유
I have tried warm water
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 70
지난 30일: 251
전체 시간: 23,117
