주요 콘텐츠로 건너뛰기
How to Unclog a Fountain Pen
필요한 것
  1. How to Unclog a Fountain Pen, How to Unclog a Fountain Pen: 1 단계, 이미지 2개 중 1개 How to Unclog a Fountain Pen, How to Unclog a Fountain Pen: 1 단계, 이미지 2개 중 2개
    • Disassemble the fountain pen.
  2. How to Unclog a Fountain Pen: 2 단계, 이미지 2개 중 1개 How to Unclog a Fountain Pen: 2 단계, 이미지 2개 중 2개
    • Remove the ink cartridge from the section.
    • Run the section under warm running water.
  3. How to Unclog a Fountain Pen: 3 단계, 이미지 3개 중 1개 How to Unclog a Fountain Pen: 3 단계, 이미지 3개 중 2개 How to Unclog a Fountain Pen: 3 단계, 이미지 3개 중 3개
    • Remove the feed and nib from the section.
    • Separate the nib and the feed.
    • Run the nib and feed under warm water and use a soft bristle toothbrush to gently scrub the ink residue on the two pieces.
  4. How to Unclog a Fountain Pen: 4 단계, 이미지 1개 중 1개
    • Leave the nib, feed, and section to air dry until completely dry.
    • Reassemble and test the pen
    • If the fountain pen still does not work, continue to Step 5.
  5. How to Unclog a Fountain Pen: 5 단계, 이미지 3개 중 1개 How to Unclog a Fountain Pen: 5 단계, 이미지 3개 중 2개 How to Unclog a Fountain Pen: 5 단계, 이미지 3개 중 3개
    • To create the cleaning solution, mix equal parts of ammonia and water in a container.
    • Add a few drops of dish soap to the solution and stir.
  6. How to Unclog a Fountain Pen: 6 단계, 이미지 3개 중 1개 How to Unclog a Fountain Pen: 6 단계, 이미지 3개 중 2개 How to Unclog a Fountain Pen: 6 단계, 이미지 3개 중 3개
    • Drop the nib and feed in the cleaning solution.
    • Soak the pieces for approximately 12-24 hours.
  7. How to Unclog a Fountain Pen: 7 단계, 이미지 1개 중 1개
    • Leave the nib, feed, and section to airdry until completely dry.
  8. How to Unclog a Fountain Pen: 8 단계, 이미지 3개 중 1개 How to Unclog a Fountain Pen: 8 단계, 이미지 3개 중 2개 How to Unclog a Fountain Pen: 8 단계, 이미지 3개 중 3개
    • When it's dry, replace the ink cartridge or converter and reassemble the fountain pen.
결론
Reassemble your fountain pen and you are ready to write.
작성자
3다른 기여자 명과 함께
Mara Alagon
회원 가입일: 01/30/24
157 평판
안내서 1개를 작성함
UC Davis, Team 2-2, Andersen Winter 2024 UC Davis, Team 2-2, Andersen Winter 2024 회원
UCD-ANDERSEN-W24S2G2
3 회원들
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 46
지난 30일: 157
전체 시간: 1,623
