주요 콘텐츠로 건너뛰기
How to Unclog a Keurig BVMC-KG5
필요한 것
  1. How to Unclog a Keurig BVMC-KG5, How to Unclog a Keurig BVMC-KG5: 1 단계, 이미지 1/1
    • Unplug your Keurig.
  2. How to Unclog a Keurig BVMC-KG5: 2 단계, 이미지 1/1
    • Disassemble all of the parts. This includes: water tank, lid, K-cup holder, and both pieces of the tray where the coffee cup sits.
    • You should not need a screwdriver for this. All of the parts you are disassembling are easily removable by hand.
    • Wash all of the parts in warm, soapy water. Dry well.
  3. How to Unclog a Keurig BVMC-KG5: 3 단계, 이미지 1/3 How to Unclog a Keurig BVMC-KG5: 3 단계, 이미지 2/3 How to Unclog a Keurig BVMC-KG5: 3 단계, 이미지 3/3
    • Unclog the needles using a slightly bent paperclip.
    • With the top of the Keuring open, insert the free end of the paperclip into the three small holes surrounding the needle that pierces the K-Cup.
    • Jiggle the paperclip to loosen any debris.
  4. How to Unclog a Keurig BVMC-KG5: 4 단계, 이미지 1/1
    • Wipe the whole machine down and reassemble all of the previously removed parts.
  5. How to Unclog a Keurig BVMC-KG5: 5 단계, 이미지 1/1
    • Fill the water tank with a half water-half vinegar solution.
    • Do not use straight vinegar. It can damage the machine's parts due to the acidity.
    • Run the water-vinegar solution through the machine until you have emptied the tank.
    • Run clean water through the machine. You may have to repeat this step several times to get all of the water-vinegar solution out of the pipes.
결론
Repeat this process every 2-3 months for optimal use of your Keurig, and to increase the lifespan of your coffee brewer.
다른 2명이 해당 안내서를 완성하였습니다.
Hunter Ashbrook
회원 가입일: 03/21/16
155 평판
안내서 1개 작성함
Michigan Tech, Team 1-1, Lauer Spring 2016 Michigan Tech, Team 1-1, Lauer Spring 2016 회원
MTU-LAUER-S16S1G1
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 18
전체 시간: 5,658
