주요 콘텐츠로 건너뛰기
How to Unclog a Samsung WF350ANR Washing Machine Filter
필요한 것
  1. How to Unclog a Samsung WF350ANR Washing Machine Filter, How to Unclog a Samsung WF350ANR Washing Machine Filter: 1 단계, 이미지 1/3 How to Unclog a Samsung WF350ANR Washing Machine Filter, How to Unclog a Samsung WF350ANR Washing Machine Filter: 1 단계, 이미지 2/3 How to Unclog a Samsung WF350ANR Washing Machine Filter, How to Unclog a Samsung WF350ANR Washing Machine Filter: 1 단계, 이미지 3/3
    • Caution: Before beginning this guide, be sure to turn the washing machine off and unplug it from the outlet.
    • The water filter is typically located at the bottom right or bottom left. In this case, it is located at the bottom right.
    • Place a bucket under the water filter to capture excess water before moving on to the next steps.
  2. How to Unclog a Samsung WF350ANR Washing Machine Filter: 2 단계, 이미지 1/3 How to Unclog a Samsung WF350ANR Washing Machine Filter: 2 단계, 이미지 2/3 How to Unclog a Samsung WF350ANR Washing Machine Filter: 2 단계, 이미지 3/3
    • Jiggle the water filter compartment while pulling it towards yourself to remove the compartment.
  3. How to Unclog a Samsung WF350ANR Washing Machine Filter: 3 단계, 이미지 1/3 How to Unclog a Samsung WF350ANR Washing Machine Filter: 3 단계, 이미지 2/3 How to Unclog a Samsung WF350ANR Washing Machine Filter: 3 단계, 이미지 3/3
    • To open the water filter, move the knob to the left with your hand.
    • With your other hand, hold the bucket underneath the filter to capture the excess water.
  4. How to Unclog a Samsung WF350ANR Washing Machine Filter: 4 단계, 이미지 1/3 How to Unclog a Samsung WF350ANR Washing Machine Filter: 4 단계, 이미지 2/3 How to Unclog a Samsung WF350ANR Washing Machine Filter: 4 단계, 이미지 3/3
    • Remove the water filter.
    • Clean hard-to-reach places in the filter with a toothbrush and excess water that was captured with the bucket.
  5. How to Unclog a Samsung WF350ANR Washing Machine Filter: 5 단계, 이미지 1/2 How to Unclog a Samsung WF350ANR Washing Machine Filter: 5 단계, 이미지 2/2
    • Use the toothbrush to clean the slot in the washing machine where the water filter is inserted.
  6. How to Unclog a Samsung WF350ANR Washing Machine Filter: 6 단계, 이미지 1/3 How to Unclog a Samsung WF350ANR Washing Machine Filter: 6 단계, 이미지 2/3 How to Unclog a Samsung WF350ANR Washing Machine Filter: 6 단계, 이미지 3/3
    • Inspect the inside to make sure there is no leftover lint or unnecessary objects that can clog the water filter.
  7. How to Unclog a Samsung WF350ANR Washing Machine Filter: 7 단계, 이미지 1/3 How to Unclog a Samsung WF350ANR Washing Machine Filter: 7 단계, 이미지 2/3 How to Unclog a Samsung WF350ANR Washing Machine Filter: 7 단계, 이미지 3/3
    • Place the water filter back into the washing machine.
    • Turn the filter to the right to tighten it.
  8. How to Unclog a Samsung WF350ANR Washing Machine Filter: 8 단계, 이미지 1/2 How to Unclog a Samsung WF350ANR Washing Machine Filter: 8 단계, 이미지 2/2
    • Pour the bucket of excess water down a drain.
    • If a lot of lint or hair was cleaned out of the water filter, make sure to grab it with one hand as you drain out the water with the other hand.
    • Discard the lint and hair in the trash.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Jasmine Andrade
회원 가입일: 04/11/21
181 평판
안내서 1개 작성함
CSU Los Angeles, Team S1-G9, Harris Spring 2021 CSU Los Angeles, Team S1-G9, Harris Spring 2021 회원
CSULA-HARRIS-S21S1G9
1 회원
안내서 1개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 16
30일 전: 60
전체 시간: 493
