주요 콘텐츠로 건너뛰기
How to Unclog a Shark Rocket Deluxe Pro Vacuum
필요한 것
  1. How to Unclog a Shark Rocket Deluxe Pro Vacuum, How to Unclog a Shark Rocket Deluxe Pro Vacuum: 1 단계, 이미지 2개 중 1개 How to Unclog a Shark Rocket Deluxe Pro Vacuum, How to Unclog a Shark Rocket Deluxe Pro Vacuum: 1 단계, 이미지 2개 중 2개
    • Press the wand release button to remove the vacuum body from the roller brush and wand.
  2. How to Unclog a Shark Rocket Deluxe Pro Vacuum: 2 단계, 이미지 2개 중 1개 How to Unclog a Shark Rocket Deluxe Pro Vacuum: 2 단계, 이미지 2개 중 2개
    • Press the button at the bottom of the power cord on the dust bin.
    • Pull off the attached piece.
    • Remove the small filter from the piece.
  3. How to Unclog a Shark Rocket Deluxe Pro Vacuum: 3 단계, 이미지 2개 중 1개 How to Unclog a Shark Rocket Deluxe Pro Vacuum: 3 단계, 이미지 2개 중 2개
    • Pull the lever on top of the dust bin to expose the main filters.
  4. How to Unclog a Shark Rocket Deluxe Pro Vacuum: 4 단계, 이미지 3개 중 1개 How to Unclog a Shark Rocket Deluxe Pro Vacuum: 4 단계, 이미지 3개 중 2개 How to Unclog a Shark Rocket Deluxe Pro Vacuum: 4 단계, 이미지 3개 중 3개
    • Carefully squeeze and remove the top filter.
    • Underneath that filter is a second filter. Pull the tab to remove it.
  5. How to Unclog a Shark Rocket Deluxe Pro Vacuum: 5 단계, 이미지 3개 중 1개 How to Unclog a Shark Rocket Deluxe Pro Vacuum: 5 단계, 이미지 3개 중 2개 How to Unclog a Shark Rocket Deluxe Pro Vacuum: 5 단계, 이미지 3개 중 3개
    • Squeeze the release on the bottom of the dustbin.
    • Remove the dust bin from the base.
    • Pop the lid open using the slider.
    • Empty the dust bin into the trash.
  6. How to Unclog a Shark Rocket Deluxe Pro Vacuum: 6 단계, 이미지 3개 중 1개 How to Unclog a Shark Rocket Deluxe Pro Vacuum: 6 단계, 이미지 3개 중 2개 How to Unclog a Shark Rocket Deluxe Pro Vacuum: 6 단계, 이미지 3개 중 3개
    • Rinse and wipe the plastic pieces removed earlier.
    • Do not use soap.
    • Set the pieces aside to air-dry.
  7. How to Unclog a Shark Rocket Deluxe Pro Vacuum: 7 단계, 이미지 3개 중 1개 How to Unclog a Shark Rocket Deluxe Pro Vacuum: 7 단계, 이미지 3개 중 2개 How to Unclog a Shark Rocket Deluxe Pro Vacuum: 7 단계, 이미지 3개 중 3개
    • Place the filters in your sink and rinse out the dirt.
    • Squeeze out any excess water and allow them to air-dry overnight before reinstalling.
    • DO NOT USE SOAP.
  8. How to Unclog a Shark Rocket Deluxe Pro Vacuum: 8 단계, 이미지 3개 중 1개 How to Unclog a Shark Rocket Deluxe Pro Vacuum: 8 단계, 이미지 3개 중 2개 How to Unclog a Shark Rocket Deluxe Pro Vacuum: 8 단계, 이미지 3개 중 3개
    • With a wet rag wipe out any dirt buildup on the vacuum casing.
  9. How to Unclog a Shark Rocket Deluxe Pro Vacuum: 9 단계, 이미지 3개 중 1개 How to Unclog a Shark Rocket Deluxe Pro Vacuum: 9 단계, 이미지 3개 중 2개 How to Unclog a Shark Rocket Deluxe Pro Vacuum: 9 단계, 이미지 3개 중 3개
    • Turn the base of the vacuum on its side.
    • With your scissors, cut any wrapped hairs or strings that may be stuck on the rollers.
  10. How to Unclog a Shark Rocket Deluxe Pro Vacuum: 10 단계, 이미지 2개 중 1개 How to Unclog a Shark Rocket Deluxe Pro Vacuum: 10 단계, 이미지 2개 중 2개
    • Lastly, insert your drain snake into the tube of the vacuum to dislodge any large stuck items.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Savannah Webb
회원 가입일: 06/13/21
208 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 51
전체 시간: 3,040
