주요 콘텐츠로 건너뛰기
How to Unclog a Sink Using a Wet Vacuum
필요한 것
  1. How to Unclog a Sink Using a Wet Vacuum, How to Unclog a Sink Using a Wet Vacuum: 1 단계, 이미지 1개 중 1개
    • Before starting, make sure your sink is empty.
    • Clear out the sink using a cup or sponge to remove any standing water for better suction.
  2. How to Unclog a Sink Using a Wet Vacuum: 2 단계, 이미지 3개 중 1개 How to Unclog a Sink Using a Wet Vacuum: 2 단계, 이미지 3개 중 2개 How to Unclog a Sink Using a Wet Vacuum: 2 단계, 이미지 3개 중 3개
    • If your stopper is attached to the p-trap, removing it may cause water to leak. Be ready to duct tape it or have a towel or small bucket to catch the leak.
    • If your sink has a stopper plug, take it out.
    • This will give direct access to the clogged drain and improve suction.
    • Most sinks have detached stopper plugs. However, some sink stoppers are connected to the p-trap, so check which type you have and adjust accordingly.
  3. How to Unclog a Sink Using a Wet Vacuum: 3 단계, 이미지 2개 중 1개 How to Unclog a Sink Using a Wet Vacuum: 3 단계, 이미지 2개 중 2개
    • If your sink has an overflow hole, cover it with duct tape or a towel to seal it.
    • This helps maintain suction and prevents water from leaking through it.
  4. How to Unclog a Sink Using a Wet Vacuum: 4 단계, 이미지 3개 중 1개 How to Unclog a Sink Using a Wet Vacuum: 4 단계, 이미지 3개 중 2개 How to Unclog a Sink Using a Wet Vacuum: 4 단계, 이미지 3개 중 3개
    • Ensure that your vacuum can suck up water, using a regular vacuum could cause damage to the vacuum.
    • Before setting up, open your wet vacuum so it’s ready for use.
  5. How to Unclog a Sink Using a Wet Vacuum: 5 단계, 이미지 3개 중 1개 How to Unclog a Sink Using a Wet Vacuum: 5 단계, 이미지 3개 중 2개 How to Unclog a Sink Using a Wet Vacuum: 5 단계, 이미지 3개 중 3개
    • Check the settings on your vacuum to see if your filter is good for wet or dry use.
    • Remove the filter to avoid potential damage.
    • As a precaution, it's recommended to remove the filter even if it's designed for wet use to prevent potential damage over time.
  6. How to Unclog a Sink Using a Wet Vacuum: 6 단계, 이미지 2개 중 1개 How to Unclog a Sink Using a Wet Vacuum: 6 단계, 이미지 2개 중 2개
    • Position the vacuum hose directly over the drain.
    • Press the hose firmly against the drain.
    • If needed, add an inch of water to the sink before attaching the hose, this can help improve suction.
  7. How to Unclog a Sink Using a Wet Vacuum: 7 단계, 이미지 3개 중 1개 How to Unclog a Sink Using a Wet Vacuum: 7 단계, 이미지 3개 중 2개 How to Unclog a Sink Using a Wet Vacuum: 7 단계, 이미지 3개 중 3개
    • Switch the vacuum to wet mode and turn it on.
    • Hold the hose over the drain for about two minutes to pull up the clog.
  8. How to Unclog a Sink Using a Wet Vacuum: 8 단계, 이미지 2개 중 1개 How to Unclog a Sink Using a Wet Vacuum: 8 단계, 이미지 2개 중 2개
    • The vacuum tank may fill up quickly, so be prepared to empty it once or twice during the process.
    • Check the vacuum hose for debris every few minutes.
    • If hair or gunk comes up, remove it by hand or with needle-nose pliers before continuing.
  9. How to Unclog a Sink Using a Wet Vacuum: 9 단계, 이미지 2개 중 1개 How to Unclog a Sink Using a Wet Vacuum: 9 단계, 이미지 2개 중 2개
    • Remove the hose from the sink.
    • Run water to see if the clog is cleared. If water still drains slowly, repeat the process or consider seeking professional assistance.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Monica Collazo-Cofino
회원 가입일: 01/12/25
214 평판
안내서 1개를 작성함
York University, Team 3-12, Woodhouse Winter 2025 York University, Team 3-12, Woodhouse Winter 2025 회원
YORK-WOODHOUSE-W25S3G12
2 회원들
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 13
지난 30일: 62
전체 시간: 382
