주요 콘텐츠로 건너뛰기
How to Unclog a Sink without Harsh Chemicals
필요한 것
  1. How to Unclog a Sink without Harsh Chemicals, How to Unclog a Sink without Harsh Chemicals: 1 단계, 이미지 1/1
    • Measure two cups of tap water.
    • Pour the tap water into a tea kettle and heat the water until it boils.
    • Boiling water may cause burns. Handle with care. Turn stove off after use.
    • Slowly pour boiling water down the clogged drain.
    • This is to avoid splash back and possible injury.
  2. How to Unclog a Sink without Harsh Chemicals: 2 단계, 이미지 1/2 How to Unclog a Sink without Harsh Chemicals: 2 단계, 이미지 2/2
    • Measure one cup of baking soda.
    • Pour baking soda into a large mixing bowl.
  3. How to Unclog a Sink without Harsh Chemicals: 3 단계, 이미지 1/3 How to Unclog a Sink without Harsh Chemicals: 3 단계, 이미지 2/3 How to Unclog a Sink without Harsh Chemicals: 3 단계, 이미지 3/3
    • Measure one cup of vinegar.
    • Pour vinegar into the bowl with the baking soda.
    • Alternatively, mix in one cup of lemon juice as a substitution for the vinegar.
    • Do not use both vinegar and lemon juice.
    • Use a spatula to mix the contents until they form a paste.
  4. How to Unclog a Sink without Harsh Chemicals: 4 단계, 이미지 1/1
    • Pour the combination down the drain using a spatula.
  5. How to Unclog a Sink without Harsh Chemicals: 5 단계, 이미지 1/1
    • Measure two additional cups of tap water.
    • Allow the water to drain completely.
    • Run the tap for approximately 5 - 10 minutes.
    • It might take more than one attempt to clear the clog. Repeat this procedure as needed.
결승점
Casper Savoie
회원 가입일: 01/12/22
124 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 20
전체 시간: 540
