주요 콘텐츠로 건너뛰기
How to Unclog a Sink
필요한 것
  1. How to Unclog a Sink, How to Unclog a Sink: 1 단계, 이미지 3개 중 1개 How to Unclog a Sink, How to Unclog a Sink: 1 단계, 이미지 3개 중 2개 How to Unclog a Sink, How to Unclog a Sink: 1 단계, 이미지 3개 중 3개
    • Begin by filling the sink halfway full with water.
    • Pump the plunger rapidly for 30 seconds.
    • Do NOT break seal between plunger and drain.
    • Repeat this process 4 to 6 times.
    • Wait 20 min before proceeding to the next step. This will allow some debris to flow down the pipes.
  2. How to Unclog a Sink: 2 단계, 이미지 2개 중 1개 How to Unclog a Sink: 2 단계, 이미지 2개 중 2개
    • Place a bucket below the P-trap .
    • The curved white pipe is called the P-trap.
    • These next few steps may get a bit messy. Proceed with caution.
  3. How to Unclog a Sink: 3 단계, 이미지 3개 중 1개 How to Unclog a Sink: 3 단계, 이미지 3개 중 2개 How to Unclog a Sink: 3 단계, 이미지 3개 중 3개
    • Carefully untwist slip nuts by hand.
    • If you are unable to remove by hand, use a slip joint plier to remove the slip nuts.
    • The nuts at the ends of the P-trap are called slip nuts.
  4. How to Unclog a Sink: 4 단계, 이미지 3개 중 1개 How to Unclog a Sink: 4 단계, 이미지 3개 중 2개 How to Unclog a Sink: 4 단계, 이미지 3개 중 3개
    • Use a small wire brush to clean the P-trap.
    • You may want to clean the connecting pipes with the wire brush as well.
  5. How to Unclog a Sink: 5 단계, 이미지 3개 중 1개 How to Unclog a Sink: 5 단계, 이미지 3개 중 2개 How to Unclog a Sink: 5 단계, 이미지 3개 중 3개
    • Carefully rinse the P-trap with hot water.
    • Do NOT rinse the P-trap in the sink you are working on because there is no connecting pipe to catch the water.
  6. How to Unclog a Sink: 6 단계, 이미지 3개 중 1개 How to Unclog a Sink: 6 단계, 이미지 3개 중 2개 How to Unclog a Sink: 6 단계, 이미지 3개 중 3개
    • Reattach the P-trap.
  7. How to Unclog a Sink: 7 단계, 이미지 3개 중 1개 How to Unclog a Sink: 7 단계, 이미지 3개 중 2개 How to Unclog a Sink: 7 단계, 이미지 3개 중 3개
    • Pour 1/2 cup of baking soda down the drain.
    • Pour 1/2 cup of distilled white vinegar down the drain.
    • Quickly cover the drain with a drain stopper.
    • This keeps the reaction in the pipes.
  8. How to Unclog a Sink: 8 단계, 이미지 2개 중 1개 How to Unclog a Sink: 8 단계, 이미지 2개 중 2개
    • As soon as the fizzing stops, pour another 1/2 cup of white distilled vinegar down the drain.
    • Cover again with a drain stopper.
    • Let the sink sit for 20 min.
  9. How to Unclog a Sink: 9 단계, 이미지 3개 중 1개 How to Unclog a Sink: 9 단계, 이미지 3개 중 2개 How to Unclog a Sink: 9 단계, 이미지 3개 중 3개
    • Boil 1 gallon of water with a boiler.
    • The boiler will get hot. Handle with care.
    • Pour the boiling water down the sink to flush out any remaining debris.
결승점
다른 5명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Daniel Sanchez
회원 가입일: 09/29/15
299 평판
안내서 1개를 작성함
Cal Poly, Team 14-2, Green Fall 2015 Cal Poly, Team 14-2, Green Fall 2015 회원
CPSU-GREEN-F15S14G2
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 47
전체 시간: 3,796
