주요 콘텐츠로 건너뛰기
How to Unclog a Toilet Drainpipe
필요한 것
  1. How to Unclog a Toilet Drainpipe, How to Unclog a Toilet Drainpipe: 1 단계, 이미지 1/1
    • Turn off the water supply.
    • The switch of water supply may locate differently depends on different pipe structure. Find it either left or right of toilet bowl on the floor.
  2. How to Unclog a Toilet Drainpipe: 2 단계, 이미지 1/1
    • Flush the toilet in order to empty the water tank and the bowl.
  3. How to Unclog a Toilet Drainpipe: 3 단계, 이미지 1/1
    • Use a sponge or paper towel to clean the water left in the water tank.
    • Make sure you wear the gloves.
  4. How to Unclog a Toilet Drainpipe: 4 단계, 이미지 1/1
    • Remove the water supply pipe from the toilet bowl.
  5. How to Unclog a Toilet Drainpipe: 5 단계, 이미지 1/3 How to Unclog a Toilet Drainpipe: 5 단계, 이미지 2/3 How to Unclog a Toilet Drainpipe: 5 단계, 이미지 3/3
    • Find the floor bolts and remove the decorative cap off the bolts.
    • Remove the bolts with a wrench.
  6. How to Unclog a Toilet Drainpipe: 6 단계, 이미지 1/1
    • After removing the floor bolts, wiggle the bowl and remove it.
    • Remove anything that may be stuck in the pipe.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Chen Liang
회원 가입일: 07/08/20
160 평판
안내서 1개 작성함
York University, Team S1-G1, Allen Summer 2020 York University, Team S1-G1, Allen Summer 2020 회원
YORK-ALLEN-SU20S1G1
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 26
전체 시간: 1,259
