주요 콘텐츠로 건너뛰기
How to Unclog a Toilet with an Auger
필요한 것
  1. How to Unclog a Toilet with an Auger, How to Unclog a Toilet with an Auger: 1 단계, 이미지 1/2 How to Unclog a Toilet with an Auger, How to Unclog a Toilet with an Auger: 1 단계, 이미지 2/2
    • Turn the auger's handle counterclockwise and pull it towards you to retract the snake.
  2. How to Unclog a Toilet with an Auger: 2 단계, 이미지 1/2 How to Unclog a Toilet with an Auger: 2 단계, 이미지 2/2
    • Place the auger directly into the toilet bowl.
    • The end of the auger can scratch the toilet bowl, so use caution.
  3. How to Unclog a Toilet with an Auger: 3 단계, 이미지 1/1
    • Turn the handle clockwise to push the auger down the drain.
    • Stop when the handle gets stiff.
  4. How to Unclog a Toilet with an Auger: 4 단계, 이미지 1/2 How to Unclog a Toilet with an Auger: 4 단계, 이미지 2/2
    • Turn the handle counterclockwise while pulling it towards you to retract the auger.
    • Remove the auger from the toilet and dispose of anything caught by the metal.
  5. How to Unclog a Toilet with an Auger: 5 단계, 이미지 1/1
    • Flush the toilet to see if the water resets to a normal level.
    • Be prepared to push and retract the auger multiple times to clear the clog.
  6. How to Unclog a Toilet with an Auger: 6 단계, 이미지 1/1
    • Once the toilet is unclogged, place the auger in a towel to dry.
결승점
Dante
회원 가입일: 01/16/24
133 평판
안내서 1개 작성함
York University, Team 48-13, O'Regan Winter 2024 York University, Team 48-13, O'Regan Winter 2024 회원
YORK-O'REGAN-W24S48G13
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 78
