주요 콘텐츠로 건너뛰기
How to Unclog a Toilet with an Auger
필요한 것
  1. How to Unclog a Toilet with an Auger, How to Unclog a Toilet with an Auger: 1 단계, 이미지 2개 중 1개 How to Unclog a Toilet with an Auger, How to Unclog a Toilet with an Auger: 1 단계, 이미지 2개 중 2개
    • Turn the auger's handle counterclockwise and pull it towards you to retract the snake.
  2. How to Unclog a Toilet with an Auger: 2 단계, 이미지 2개 중 1개 How to Unclog a Toilet with an Auger: 2 단계, 이미지 2개 중 2개
    • Place the auger directly into the toilet bowl.
    • The end of the auger can scratch the toilet bowl, so use caution.
  3. How to Unclog a Toilet with an Auger: 3 단계, 이미지 1개 중 1개
    • Turn the handle clockwise to push the auger down the drain.
    • Stop when the handle gets stiff.
  4. How to Unclog a Toilet with an Auger: 4 단계, 이미지 2개 중 1개 How to Unclog a Toilet with an Auger: 4 단계, 이미지 2개 중 2개
    • Turn the handle counterclockwise while pulling it towards you to retract the auger.
    • Remove the auger from the toilet and dispose of anything caught by the metal.
  5. How to Unclog a Toilet with an Auger: 5 단계, 이미지 1개 중 1개
    • Flush the toilet to see if the water resets to a normal level.
    • Be prepared to push and retract the auger multiple times to clear the clog.
  6. How to Unclog a Toilet with an Auger: 6 단계, 이미지 1개 중 1개
    • Once the toilet is unclogged, place the auger in a towel to dry.
결승점
작성자
1다른 기여자 명과 함께
Dante
회원 가입일: 01/16/24
133 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 7
전체 시간: 161
