소개
It’s your worst nightmare. You go to relieve yourself and attempt to get rid of the evidence, only to realize the toilet isn’t cooperating. This happens to the best of us, so you’re not alone. Luckily, this common problem comes with an easy fix using a basic, affordable tool: the mighty toilet plunger.
필요한 것
A proper toilet plunger has a funnel-shaped flange extending from the bottom of the rubber cup.
A sink plunger just uses a rubber cup, which doesn't form a tight seal inside the toilet bowl.
Insert the toilet plunger into the toilet bowl, making sure that the narrow bell-shaped flange at the end of the plunger is inserted into the drain at the bottom of the toilet bowl.
Once inserted, twist the plunger back and forth a couple of times to make sure it's firmly seated at the bottom of the toilet bowl.
다른 3명이 해당 안내서를 완성하였습니다.
