주요 콘텐츠로 건너뛰기
How to Unclog an Epson ET-2760 Printhead
필요한 것
  1. How to Unclog an Epson ET-2760 Printhead, How to Unclog an Epson ET-2760 Printhead: 1 단계, 이미지 2개 중 1개 How to Unclog an Epson ET-2760 Printhead, How to Unclog an Epson ET-2760 Printhead: 1 단계, 이미지 2개 중 2개
    • Begin a print of any kind, or a nozzle check.
    • Once the print has begun, pull the power cable out mid-print.
  2. How to Unclog an Epson ET-2760 Printhead: 2 단계, 이미지 2개 중 1개 How to Unclog an Epson ET-2760 Printhead: 2 단계, 이미지 2개 중 2개
    • Open the printer, then pull out the half-printed paper through the slot.
    • Place a thick paper towel or rag under the printhead.
  3. How to Unclog an Epson ET-2760 Printhead: 3 단계, 이미지 3개 중 1개 How to Unclog an Epson ET-2760 Printhead: 3 단계, 이미지 3개 중 2개 How to Unclog an Epson ET-2760 Printhead: 3 단계, 이미지 3개 중 3개
    • Remove the single screw with a Phillips #0 screwdriver.
    • Unclip the two white plastic clips.
    • Lift the top cover off of the printhead.
  4. How to Unclog an Epson ET-2760 Printhead: 4 단계, 이미지 1개 중 1개
    • Unclip the four ink cartridges from the printhead by pulling the small tabs on top of the cartridges.
    • Be sure not to disconnect the ink lines from the cartridges. Simply set the connected cartridges to the side of the printhead.
  5. How to Unclog an Epson ET-2760 Printhead: 5 단계, 이미지 2개 중 1개 How to Unclog an Epson ET-2760 Printhead: 5 단계, 이미지 2개 중 2개
    • Fill a syringe with printhead cleaning solution and place the syringe tip over the holes left by the cartridges.
  6. How to Unclog an Epson ET-2760 Printhead: 6 단계, 이미지 1개 중 1개
    • Begin to flush the manufacturer's recommended amount of solution through each hole onto the paper towel.
    • If necessary, swap out the paper towel in between flushes to prevent any solution from entering the printer.
  7. How to Unclog an Epson ET-2760 Printhead: 7 단계, 이미지 1개 중 1개
    • Remove the paper towel from under the printhead.
  8. How to Unclog an Epson ET-2760 Printhead: 8 단계, 이미지 3개 중 1개 How to Unclog an Epson ET-2760 Printhead: 8 단계, 이미지 3개 중 2개 How to Unclog an Epson ET-2760 Printhead: 8 단계, 이미지 3개 중 3개
    • Reattach each ink cartridge into their original positions.
    • Reattach the two printhead cover clips back onto the printhead.
    • Screw the single screw back into place with a Phillips #0 screwdriver.
  9. How to Unclog an Epson ET-2760 Printhead: 9 단계, 이미지 1개 중 1개
    • Perform an automatic cleaning to ensure that any ink residue is removed.
결론
Enjoy your clean printhead!
다른 18명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Jack Buttry
회원 가입일: 02/26/22
517 평판
안내서 1개를 작성함
30가이드 댓글
Simple but to the point tutorial that detailed every step including the tools and supplies needed. Photos helped tremendously too. Thank you.
Mark DiRollo - 답글
Where do I find out the "manufacturer's recommended amount of solution" per flush?
Stelios Makrinos - 답글
Usually it's 5ml
Casper Hon -
But it seems that ink isn't even getting to my yellow and blue heads. At least, the test print shows no yellow or blue at all.
How can I get at the exit (valves?) on the ink storage tanks to make sure they're clear -- without breaking the printer?
Thanks!
warble58 - 답글
Me too! No yellow or blue coming through.
Tracy - 답글
댓글 쓰기
조회 통계:
지난 24시간: 60
지난 7일: 351
지난 30일: 1,487
전체 시간: 93,006
