주요 콘텐츠로 건너뛰기
How to Unjam and Clean a DiseZeit Z1M
  1. How to Unjam and Clean a DiseZeit Z1M, How to Unjam and Clean a DiseZeit Z1M: 1 단계, 이미지 3개 중 1개 How to Unjam and Clean a DiseZeit Z1M, How to Unjam and Clean a DiseZeit Z1M: 1 단계, 이미지 3개 중 2개 How to Unjam and Clean a DiseZeit Z1M, How to Unjam and Clean a DiseZeit Z1M: 1 단계, 이미지 3개 중 3개
    • Unscrew the bottom of your grinder where the coffee grounds are held and remove it from the grinder's body.
  2. How to Unjam and Clean a DiseZeit Z1M: 2 단계, 이미지 3개 중 1개 How to Unjam and Clean a DiseZeit Z1M: 2 단계, 이미지 3개 중 2개 How to Unjam and Clean a DiseZeit Z1M: 2 단계, 이미지 3개 중 3개
    • Take off the cap of the grinder that has the grinding handle on it by pulling it off.
    • Empty out the grinder body.
  3. How to Unjam and Clean a DiseZeit Z1M: 3 단계, 이미지 3개 중 1개 How to Unjam and Clean a DiseZeit Z1M: 3 단계, 이미지 3개 중 2개 How to Unjam and Clean a DiseZeit Z1M: 3 단계, 이미지 3개 중 3개
    • Put the cap of the grinder back on to the body.
    • Hold the handle on the cap still and turn the grinder upside down so you can see the bottom of the grinder body.
  4. How to Unjam and Clean a DiseZeit Z1M: 4 단계, 이미지 1개 중 1개
    • Look at the markings on the grinder to see which direction the dial should be turned to make the grounds finer or coarser.
  5. How to Unjam and Clean a DiseZeit Z1M: 5 단계, 이미지 3개 중 1개 How to Unjam and Clean a DiseZeit Z1M: 5 단계, 이미지 3개 중 2개 How to Unjam and Clean a DiseZeit Z1M: 5 단계, 이미지 3개 중 3개
    • Unscrew the dial towards the coarser setting until the dial becomes fully unscrewed from the grinder's body.
    • The grinder has noted counter-clockwise as the direction for coarser grounds.
    • For reassembly, see Step 12.
  6. How to Unjam and Clean a DiseZeit Z1M: 6 단계, 이미지 2개 중 1개 How to Unjam and Clean a DiseZeit Z1M: 6 단계, 이미지 2개 중 2개
    • Pull out the metal plate from the body of the grinder.
    • For reassembly, see Step 11.
  7. How to Unjam and Clean a DiseZeit Z1M: 7 단계, 이미지 2개 중 1개 How to Unjam and Clean a DiseZeit Z1M: 7 단계, 이미지 2개 중 2개
    • Pull out the metal grinding burr.
  8. How to Unjam and Clean a DiseZeit Z1M: 8 단계, 이미지 2개 중 1개 How to Unjam and Clean a DiseZeit Z1M: 8 단계, 이미지 2개 중 2개
    • Pull out the spring around the shaft in the center of the grinder.
  9. How to Unjam and Clean a DiseZeit Z1M: 9 단계, 이미지 1개 중 1개
    • Check to see that the body of of the grinder has no more detachable parts in the center.
    • This image shows the parts you should have removed from the body of the grinder.
  10. How to Unjam and Clean a DiseZeit Z1M: 10 단계, 이미지 3개 중 1개 How to Unjam and Clean a DiseZeit Z1M: 10 단계, 이미지 3개 중 2개 How to Unjam and Clean a DiseZeit Z1M: 10 단계, 이미지 3개 중 3개
    • Gently wash the body of the grinder, the parts that were removed, and the base of the grinder that holds the coffee grounds using water and soap.
    • Make sure that all of the pieces are free of coffee bean residue before continuing.
    • Fully dry each part of the grinder before reassembling.
  11. How to Unjam and Clean a DiseZeit Z1M: 11 단계, 이미지 3개 중 1개 How to Unjam and Clean a DiseZeit Z1M: 11 단계, 이미지 3개 중 2개 How to Unjam and Clean a DiseZeit Z1M: 11 단계, 이미지 3개 중 3개
    • Put the parts of the coffee grinder back together by following steps 5 through 8 in reverse order.
    • When putting the metal plate and the grinding burr back into the grinder, first make sure to align the hole in the grinding bur and the notch in the metal plate, put the two components together, and then put them into the grinder's body.
  12. How to Unjam and Clean a DiseZeit Z1M: 12 단계, 이미지 3개 중 1개 How to Unjam and Clean a DiseZeit Z1M: 12 단계, 이미지 3개 중 2개 How to Unjam and Clean a DiseZeit Z1M: 12 단계, 이미지 3개 중 3개
    • When you screw the dial clock-wise back into the grinder's body, it can help to keep the lid of the grinder on and to hold the handle still as you turn the dial. As the dial goes farther into the grinder body, make sure to press down on the metal plate below it to allow the dial to fully screw onto the shaft of the grinder's body.
  13. How to Unjam and Clean a DiseZeit Z1M: 13 단계, 이미지 1개 중 1개
    • Your grinder is now ready to be used.
    • You can dial in your grinder by making sure the grinder dial is completely screwed onto the shaft in the grinder, and then slowly unscrewing the dial until your grounds are coarse enough for your use.
결론
Enjoy your fresh coffee!
작성자
2다른 기여자 명과 함께
Isabelle Lai
회원 가입일: 01/22/24
217 평판
안내서 1개를 작성함
UC Davis, Team 1-4, Morris Winter 2024 UC Davis, Team 1-4, Morris Winter 2024 회원
UCD-MORRIS-W24S1G4
3 회원들
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 21
전체 시간: 284
