소개
Use this video guide to upgrade CPU Core i5 to Core i7 on your iMac 27" Retina 5K Display (Late 2014 & 2015).
필요한 것
동영상 지침
거의 끝나갑니다!
To reassemble your device, follow these instructions.
결론
다른 6명이 해당 안내서를 완성하였습니다.
댓글 3개
The method you use to remove the screen is very dangerous but the guide is helpful.
PJVCC - 답글
Good tutorial also useful to replace the SSD blade.
I would not change the processor and leave the creepy fusion drive, but
save the data, split the fusion drive, replace the SSD blade with a decent NVMe SSD (e.g. 512GB) to hold the OS and programs.
You may keep the HDD for your mass data or replace it with a SSD too.
The NVMe blade is however ways faster...
Laszlo Lebrun - 답글
Buenas noches, una pregunta, para una imac 5k 2017, con i5 7500, que procesadores le puedo poner si trae el socket 1151
Markuz Lirioz - 답글
