소개
Follow this guide to add expandable SSD storage to your PlayStation 5.
Before starting this guide, make sure that your M. 2 blade SSD is compatible with Sony’s specifications. The SSD blade seen in the photos is not suitable for the expandable storage slot in the PlayStation 5.
Also, make sure that you have updated your PlayStation has been updated with the latest system software.
Before you begin, completely power down and unplug all cables from your console. Remember to follow general electrostatic discharge (ESD) safety procedures while repairing the console.
필요한 것
If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
Use a pair of tweezers or your fingernail to remove the cap from the cubby.
Use your finger to press the cap into the screw hole.
If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
Lift the stand straight up to remove it.
Do you guys sell the stand
Flip the device over so that the USB and ethernet ports are on the left side from your perspective.
Lift up the corner of the faceplate to unclip it from the case.
Use a Phillips screwdriver to remove the 17 mm-long SSD cover screw.
Use your finger to slide the SSD cover towards the top of the device to unclip it from the case.
Remove the SSD cover.
Use a Phillips screwdriver to remove the 11 mm-long SSD screw.
The screw in my PS5 was too tight and I can no longer get it off. Is there any replacement screws and spacers that anyone can recommend on Amazon UK? Many thanks in advance.
I have the same problem and need a replacement for the screw and spacer.
Use a pair of tweezers to lift and move the spacer to the appropriate slot for your chosen M.2 SSD.
What are the physical dimensions of the spacer and the screw (saw the screw is 11mm, wondering the thread size and length of the threaded portion)? Looking to buy replacements online from someone other than from Sony.
I sent my PS5 back for RMA service for visual artifacts, and it was returned to me without the screw and spacer (I had checked before sending it that the hardware was there). Seems silly to have to send the console back for replace these components, but every time I’ve called technical support - I’ve been on over hour-long wait times (haven’t gotten through to an agent yet).
If your SSD will benefit from a heat sink, follow this guide to install one.
Insert your SSD at a shallow angle into the M.2 socket.
It should be noted here that the Samsung 970 Evo Plus is NOT a PCIE 4.0 SSD (It is NOT fast enough for the PS5)
Yes! Thank you, Rowan. I added a blurb addressing that in the introduction.
Use your finger to press the SSD down until the end sits atop the spacer.
With the SSD on the spacer, insert the SSD screw through the spacer and screw it into place, securing the end of the SSD.
Use a Phillips screwdriver to tighten the 11 mm-long screw to the end of the SSD.
Forgot one last step:
- Re-attach the SSD slot cover, as per Sony's instructions: https://www.playstation.com/en-us/suppor...
Repair didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
다른 28명이 해당 안내서를 완성하였습니다.
댓글 4개
Hello!
The 11m screw that keeps the SSD in place is totally stripped -- any tips for how to remove it? I've tried the rubber band and duct tape over the screw methods, with no luck.
Se puede cortar para extraerlo con un 🪛 plano
