주요 콘텐츠로 건너뛰기
소개
Your device must be switched-on, connected to the internet and it must have installed Google account.
From Android Device manager you can:
- Find the device on the map
- Change the Lock Screen (pass the Password, PIN, Pattern Lock)
- Factory / Hard reset (!!! THIS WILL ERASE YOUR DATA!!!)
If your device is connected to the internet and you have an installed Google account on it, look at this manual.
동영상 개요
  1. Your device must be switched-on, connected to the internet and it must have installed Google account. Your device must be switched-on, connected to the internet and it must have installed Google account.
    • Your device must be switched-on, connected to the internet and it must have installed Google account.
  2. Open: www.google.com/android/devicemanager Enter in your account and Google will start searching your device.
  3. Here you have three options. The first one is "Ring device".
    • Here you have three options.
    • The first one is "Ring device".
  4. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    지금 장보기
    iPhone X Fix Kits
    지금 장보기
  5. The next option is "Lock". Your current lock screen will be replaced with a password lock. Don't use your Google account password Every time I'm using - 1234      :)
    • The next option is "Lock".
    • Your current lock screen will be replaced with a password lock. Don't use your Google account password
    • Every time I'm using - 1234 :)
  6. Now, form Settings > Security you can change your Screen Lock. Now, form Settings > Security you can change your Screen Lock. Now, form Settings > Security you can change your Screen Lock.
    • Now, form Settings > Security you can change your Screen Lock.
  7. Also you can Factory Reset your device. "This performs a factory reset on your device. Your apps, photos, music and settings will be deleted. After you erase the device, Android Device Manager will not longer work. This reset is permanent. We may not be able to wipe the content of the SD card in your device." "If your device is offline, we will perform the factory reset as soon as it goes online."
    • Also you can Factory Reset your device.
    • "This performs a factory reset on your device. Your apps, photos, music and settings will be deleted. After you erase the device, Android Device Manager will not longer work. This reset is permanent. We may not be able to wipe the content of the SD card in your device."
    • "If your device is offline, we will perform the factory reset as soon as it goes online."
  8. That's all. Did you do it successfully? Did you do it successfully?
    • That's all.
    • Did you do it successfully?
결론
다른 190명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 2013년 12월 09일
165,707 평판
안내서 305개 작성하였습니다
Master Techs Master Techs 회원
Community
287 회원들
안내서 811개 작성하였습니다
Complain loudly to Google about the following message from ADM after trying to over-ride the screen lock with a password: "Since Google has verified that a screen lock is already set, the password you entered won't be needed." THAT'S THE WHOLE F@)_#$) POINT -- You don't know the password and ADM won't let you enter another one to unlock the screen.
Trent Lucas - 답글
If you forgot your pattern lock or screen password, ADM will replace it with a new, entered from the customer. You don't need to know the password.
ZFix -
@zFix im trying this method and it says your phone, “your phone is already locked, you cannot put a new password”
can you help in any other method
regards
Haroon Gulzar -
ADM is not replacing the password. It keeps saying "Since Google has verified that a screen lock is already set, the password you entered won't be needed.".
My nephew forgot his password and we couldn't use ADM to reset it. In fact, I set a password on my Moto X to try and reset it from ADM, it says the same thing and won't reset it.
sodapop jam - 답글
ADM won't remove the password. Instead, it will generate a tmp password and you can use it to unlock the phone. Then you need to set a few passcode for the phone. The tutorial has detailed explanation on this issue: http://bit.ly/28SHO3G
kersonzine -
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 546
지난 30일: 3,368
전체 시간: 407,929
