소개
Do you have a flat tire, but don't have the time nor the strength to fill up your tires with a standard pump? Using a CO2 Cartridge is a quick and easy way to re-inflate your tires without much work compared to pumping tires full of air.
필요한 것
Figure out which tire is flat. In this case, the rear wheel is flat.
Once you're able to place the tire back in place and inflate the tire using the CO2 Cartridge, you're ready to keep riding!
다른 2명이 해당 안내서를 완성하였습니다.
