이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Inspect the damage.
Brush off any loose dirt or debris.
If you've got a particularly stubborn stain, check out Patagonia's Product Care guide.
Place your jacket in the washing machine.
Add laundry soap.
You can use soap specifically formulated to clean waterproof clothing or gentle nondetergent laundry soap.
Set the load size to small.
Set the water temperature to warm/cold.
Run the washer on a regular or permanent press cycle setting.
Once the cycle is completed, run the washer again on the rinse cycle to flush any remaining soap out of the jacket.
Take your jacket out of the washer.
Inspect your jacket.
If it looks clean and residue-free, go ahead and follow our guide to dry your jacket.
If your jacket looks or feels funny, place it back in the washer and run another rinse cycle.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 9개
I’m very happy after read this easy step of washing water proof jacket.Thanks for sharing this great post!!I bought water proof jacket from online store, and i got 60% off by using promo code; snow and rock promo codes.The jacket dries really fast and it’s 100% waterproof until i washed it.Color maintained very well, after it was washed.
The tips and suggestion was outstanding i try my husband jacket it was mess with factory work, i just buy my new washing machine from appliance connection with a reasonable prices appliances connection promo code and i get upto 40% discount on my first purchase you can also try.
Is it ok to wash two or three waterproof jackets together in the same load? Thank you!
White lining is flaking off ALL my Patagonia waterproof jackets - delaminated white liner. Refund the thousands of dollars I spent on this garbage?
They absolutely will replace it or give you store credit.
