주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Wind a Bobbin
필요한 것
  1. How to Wind a Bobbin, Gather materials: 1 단계, 이미지 3개 중 1개 How to Wind a Bobbin, Gather materials: 1 단계, 이미지 3개 중 2개 How to Wind a Bobbin, Gather materials: 1 단계, 이미지 3개 중 3개
    • You'll need:
    • A sewing machine or bobbin winder
    • An empty bobbin (compatible with your machine or tool)
    • A spool of thread
    • Your sewing machine or bobbin winder manual (optional, but helpful, especially for first-timers!)
    • Place the bobbin onto the bobbin winder pin.
    • Place the spool of thread onto the spool pin.
    • Secure the spool with a cap if your machine uses one.
    • Guide the thread through the thread path and tension discs, following your machine's manual.
    • This step is essential for maintaining proper tension during winding.
    • Attach the thread to the bobbin:
    • If the bobbin has a hole, thread the end through it from the inside out.
    • If the bobbin doesn't have a hole, wrap the thread around the bobbin manually a few times in the direction it will spin.
    • Turn on the machine if it's not already on.
    • Engage the bobbin winder by pushing the bobbin pin to the right or pressing a knob, depending on your machine.
    • Some bobbin winders will start automatically. Others will require you to engage the foot pedal.
    • Hold the thread tail for the first few seconds, then let go once it’s secure.
    • The bobbin will spin and fill with thread.
    • Most machines stop automatically when the bobbin is full. If you want to stop the winder or if you run out of thread, disengage the bobbin pin.
    • Cut the thread and remove the bobbin.
    • The ideal bobbin has:
    • Uniform distribution: The thread should be wound in smooth, uniform layers across the entire bobbin. There are no peaks, dips, or bunching in the middle or at the edges.
    • Firm tension: The thread should be tight and compact. Each layer lies flat and smooth without loops or tangles.
    • Proper fill level: When full, the thread shouldn't extend past the rim of the bobbin.
  2. How to Wind a Bobbin, Troubleshooting: 6 단계, 이미지 2개 중 1개 How to Wind a Bobbin, Troubleshooting: 6 단계, 이미지 2개 중 2개
    • Loosely wound: A messy bobbin leads to messy sewing. The bobbin must be wound tightly and with consistent tension to function properly—this applies whether you're using a sewing machine or an Expedition Sewing Awl. Unwind the bobbin, re-thread the machine, and try again. Make sure the thread passes through all tension guides.
    • Not winding: Make sure the machine is in bobbin mode. This may involve flipping a switch or pressing a knob. On some machines, the foot pedal must be pressed to activate the winder.
결승점
작성자
1다른 기여자 명과 함께
Spencer Pennington
회원 가입일: 09/09/23
25,951 평판
안내서 127개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 13
지난 30일: 52
전체 시간: 289
