주요 콘텐츠로 건너뛰기
How to access hidden settings on RCA RT2806
  1. How to access hidden settings on RCA RT2806, Power: 1 단계, 이미지 1개 중 1개
    • Turn on your TV
  2. How to access hidden settings on RCA RT2806, Open the Menu: 2 단계, 이미지 2개 중 1개 How to access hidden settings on RCA RT2806, Open the Menu: 2 단계, 이미지 2개 중 2개
    • Open the menu, by pressing the menu button on the remote
  3. How to access hidden settings on RCA RT2806, NumPad Shortcut: 3 단계, 이미지 2개 중 1개 How to access hidden settings on RCA RT2806, NumPad Shortcut: 3 단계, 이미지 2개 중 2개
    • Press the following buttons quickly after opening the menu:
    • 1-1-4-7
    • This is a column of numbers on your NumPad
    • If it doesn't work, do it more quickly after opening the menu, and check your TV model number.
결론
To close the new menu, press EXIT
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
9021007
회원 가입일: 07/13/18
4,656 평판
안내서 25개를 작성함
3가이드 댓글
You can disable the dog logo on here under General Settings.
9021007 - 답글
Thank you very much. This was driving me insane
Will McCreary -
Is there any way to save settings? Some settings are permanent, but specifically the overscan settings are reset to their original values when I power the screen off, whether by the remote power button, the power button on the screen itself. or by unplugging it.
Please advise.
Jyri Keir - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 41
전체 시간: 4,005
