소개
In this guide, you need a Case, Core, Belt, and Smart Device.
First, insert the small blue cable in the box into the Core.
The end with the MicroUSB goes into the Core.
Put the cable into its proper slot, in the bulge on the bottom of the case.
The Core is already connected, and goes with the cable fitting into the circular slot. (see second image)
Slide the bottom end of the phone 3/4 of the way in, from the top towards the bottom.
Continue sliding slowly. Make SURE the lightning connector on the cable connects to the phone.
The cable connector can sometimes slide under the phone. Avoid this.
Once the phone's bottom is flush with the case bottom, double check that the circle on the Core is lined up with the core on the case.
Now starting with the top corner without a camera, push it into the case.
Repeat step 2 with the top corner with a camera.
Enjoy your great new case! Features:
Smart Battery
Military Grade Protection
Wireless Charging
Extra Storage*
* - Optional/Varies by model
External Drive*
Powerful LED Light Array
Enjoy!
Enjoy!
다른 2명이 해당 안내서를 완성하였습니다.
