이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Occasionally, a scooter may develop a problem with the steering column where it becomes either too difficult or too easy for the user to steer the scooter. This guide will demonstrate how to adjust the tightness of the steering column by adjusting two rotating nuts on the column.
Locate the tightening assembly. The tightening assembly consists of:
An upper nut
A lower nut
If loosening the steering column, follow these steps:
Turn the upper nut counterclockwise.
Turn the lower nut counterclockwise until it is tight against the upper nut.
If the steering column is still too tight, repeat the above two steps until reaching the desired steering column looseness.
If tightening the steering column, follow these steps:
Turn the lower nut clockwise until reaching the desired steering column tightness.
Turn the upper nut clockwise until it is tight against the lower nut.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 8개
what move it with your hands? - didn't help
I couldn't turn this by hand. not sure who writes this advice. trying a pipe wrench.
Thank you for showing the way how to adjust Razor scooter. This instruction help me to adjust my scooter.
