메인 콘텐츠로 스킵하기
소개
A loose steering box can be dangerous, especially when trying to stay in a lane on a windy highway. There are a number of components in the steering system that can wear, and cause play in the steering wheel. Before assuming its the steering box causing looseness, lie under the front of the car and have a friend move the wheel back and forth in the range of play. If the arm on the steering box does not move back and forth, then it is internal wear, so continue with the procedure.
부품
지정된 부품이 없습니다.
  1. Open the (front) hood of the car.
    • Open the (front) hood of the car.
    • On the drivers side of the luggage compartment is a black seal.
  2. Remove the black seal.
    • Remove the black seal.
    • Under the seal is the adjustment screw and locking nut.
  3. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  4. If the screw threads do not rise above the locking nut then STOP: The steering box is worn out, it is time to rebuild it, or replace it! Failure to do so could result in your steering system failing.
    • If the screw threads do not rise above the locking nut then STOP: The steering box is worn out, it is time to rebuild it, or replace it! Failure to do so could result in your steering system failing.
    • Loosen the Locking nut, so the set screw can be turned with a flat head screwdriver.
    • With the wheels straight and the steering wheel centered. Turn the lash adjustment screw clockwise until it stops, but don't force it any farther!
    • Making sure that the screw does not turn, carefully tighten the locking nut.
  5. Close the hood, drive around and check the steering wheel play.
    • Close the hood, drive around and check the steering wheel play.
    • If the play is still too loose, then repeat steps 2 and 3.
    • If the steering wheel does not return to center after making a turn then it is too tight. This can cause unnecessary wear and damage your steering box! Return to step 2, but instead of tightening the lash screw, loosen it a quarter turn at a time and recheck.
결론
Congratulations! Your steering box should now have a minimal amount of play!
다른 3명이 해당 안내서를 완성하였습니다.
Noah
회원 가입일: 2012년 10월 03일
523 평판
안내서 4개 작성하였습니다
Cal Poly, Team 6-33, Regan Fall 2012 Cal Poly, Team 6-33, Regan Fall 2012 회원
CPSU-REGAN-F12S6G33
3 회원들
안내서 7개 작성하였습니다
I have over tighten the steering box. I have loosen the box all the way ,but it steel stick
larryboyd23 - 답글
This procedure skips several important steps, including setting the preload prior to adjusting the lash screw. Hint - you need a torque wrench to do it correctly. It's also advisable to check all the steering components, especially the pitman arm bushing, as the cause of steering play before blaming the steering box. I've seen several steering boxes ruined by over tightening the lash screw when the box wasn't even the problem to begin with.
Jim Thomas - 답글
great post, thanks for sharing it. Keep Posting.
https://www.sarexports.com/product/steer...
Raman Malik - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 47
전체 시간: 24,480
