주요 콘텐츠로 건너뛰기
How to adjust and maintain 2006 Iron Horse Warrior Rear Derailleur Cables
필요한 것
  1. How to adjust and maintain 2006 Iron Horse Warrior Rear Derailleur Cables, How to adjust and maintain 2006 Iron Horse Warrior Rear Derailleur Cables: 1 단계, 이미지 1/2 How to adjust and maintain 2006 Iron Horse Warrior Rear Derailleur Cables, How to adjust and maintain 2006 Iron Horse Warrior Rear Derailleur Cables: 1 단계, 이미지 2/2
    • First, we need to set the high and low bounds on position that the derailleur can travel to.
    • Shift the rear derailleur so it is in the 8th gear position.
    • Using the phillips head screw driver, adjust the screw labeled with an H so that the derailleur lines up vertically with the 8th gear (the smallest one).
  2. How to adjust and maintain 2006 Iron Horse Warrior Rear Derailleur Cables: 2 단계, 이미지 1/3 How to adjust and maintain 2006 Iron Horse Warrior Rear Derailleur Cables: 2 단계, 이미지 2/3 How to adjust and maintain 2006 Iron Horse Warrior Rear Derailleur Cables: 2 단계, 이미지 3/3
    • Set the low bound by shifting the rear derailleur to its 1st gear position. Adjust the screw labeled with a L, so the derailleur lines up vertically with the 1st gear.
    • If you are unable to get the low bound over far enough by adjusting the screw, try tightening the cable using the adjustment knob found on the shifter itself.
  3. How to adjust and maintain 2006 Iron Horse Warrior Rear Derailleur Cables: 3 단계, 이미지 1/1
    • The last thing you need to adjust is the distance the derailleur moves between gears.
    • Shift the derailleur into either the 4th or 5th gear, and adjust the hex screw found on the back of the derailleur to make sure the derailleur lines up vertically with the gear the bike is in.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Scott Kaufman
회원 가입일: 04/20/15
619 평판
안내서 3개 작성하였습니다
Cal Poly, Team 15-2, Amido Spring 2015 Cal Poly, Team 15-2, Amido Spring 2015 회원
CPSU-AMIDO-S15S15G2
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 1,814
