주요 콘텐츠로 건너뛰기
How to align Razor A steering
필요한 것
  1. How to align Razor A steering, How to align Razor A steering: 1 단계, 이미지 3개 중 1개 How to align Razor A steering, How to align Razor A steering: 1 단계, 이미지 3개 중 2개 How to align Razor A steering, How to align Razor A steering: 1 단계, 이미지 3개 중 3개
    • Locate the collar clamp near the base of the steering column.
    • Insert a 3/16" Allen wrench into the screw in the collar clamp and loosen it.
    • The collar clamp will be free to move and may slide around the steering column. When reassembling, return it to its original position.
  2. How to align Razor A steering: 2 단계, 이미지 2개 중 1개 How to align Razor A steering: 2 단계, 이미지 2개 중 2개
    • Firmly grasp the steering column and turn the wheel by hand.
    • View the scooter along the steering column. Be sure the wheel is perpendicular to the handlebars.
    • The second picture above shows a correct alignment of the steering column from this view.
결승점
다른 17명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jordyn
회원 가입일: 10/09/12
565 평판
안내서 5개를 작성함
Cal Poly, Team 9-13, Amido Fall 2012 Cal Poly, Team 9-13, Amido Fall 2012 회원
CPSU-AMIDO-F12S9G13
4 회원들
안내서 10개를 작성함
4가이드 댓글
This is so unhelpful.
Linh Tran - 답글
Great guide! Thanks so much helped me to fix my old scooter and save approx. $50
Max Kittens - 답글
Wow, fixed all the kids scooters on the block….THANK YOU!!!!!
Kathy Earhart - 답글
It worked for me for a little, but after a while the fix stopped working and i am back to where i started, and it is now as tight as it will go. They should really make the scooters better. The guide was really helpful, so thanks so much!
Alan Weinberg - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 46
전체 시간: 31,354
