주요 콘텐츠로 건너뛰기
How to apply an Adhesive Bandage on a Fingertip
필요한 것
  1. How to apply an Adhesive Bandage on a Fingertip, Cut the bandage: 1 단계, 이미지 3개 중 1개 How to apply an Adhesive Bandage on a Fingertip, Cut the bandage: 1 단계, 이미지 3개 중 2개 How to apply an Adhesive Bandage on a Fingertip, Cut the bandage: 1 단계, 이미지 3개 중 3개
    • Cut the bandage strip to length.
    • You need twice the length you want the bandage to cover. A 5 to 6 cm strip is usually enough for most small cuts.
    • Now, carefully cut a small triangle out of the bandage on both adhesive sides, up to the gauze pad. Cut the triangles out exactly in the middle. This will create four "little wings", as seen in the second picture.
  2. How to apply an Adhesive Bandage on a Fingertip, Peel off the protective films: 2 단계, 이미지 2개 중 1개 How to apply an Adhesive Bandage on a Fingertip, Peel off the protective films: 2 단계, 이미지 2개 중 2개
    • Peel off the protective films from the adhesive strip of the bandage.
  3. How to apply an Adhesive Bandage on a Fingertip, Apply the bandage: 3 단계, 이미지 3개 중 1개 How to apply an Adhesive Bandage on a Fingertip, Apply the bandage: 3 단계, 이미지 3개 중 2개 How to apply an Adhesive Bandage on a Fingertip, Apply the bandage: 3 단계, 이미지 3개 중 3개
    • Place your finger on the bandage so that the tip of the finger meets the center line.
    • Fold up the two "little wings" on the side facing you one by one and secure them on the top side of the finger.
  4. How to apply an Adhesive Bandage on a Fingertip, Apply the bandage: 4 단계, 이미지 3개 중 1개 How to apply an Adhesive Bandage on a Fingertip, Apply the bandage: 4 단계, 이미지 3개 중 2개 How to apply an Adhesive Bandage on a Fingertip, Apply the bandage: 4 단계, 이미지 3개 중 3개
    • Pull the bandage as tightly as possible over the fingertip towards the back and turn the finger with the underside facing upward.
    • Fold up the two remaining "little wings" one by one and secure them on the underside of the finger.
결론
If you have chosen the correct size of bandage, placed it properly, and pressed it firmly, it should now cover the entire fingertip. The wound should not come into contact with the adhesive surfaces.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Sebastian
회원 가입일: 08/19/18
31,187 평판
안내서 71개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 65
지난 7일: 414
지난 30일: 1,904
전체 시간: 28,515
