주요 콘텐츠로 건너뛰기
How to apply scratch-proof coating
필요한 것
  1. How to apply scratch-proof coating, How to apply scratch-proof coating: 1 단계, 이미지 1개 중 1개
    • Use Liquid Sapphire scratch proof nanotechnology coating
  2. How to apply scratch-proof coating: 2 단계, 이미지 1개 중 1개
    • Add 3 drops of Liquid Sapphire to the LCD
  3. How to apply scratch-proof coating: 3 단계, 이미지 1개 중 1개
    • With a microfibre cloth wipe up and down until the LCD surface is covered.
  4. How to apply scratch-proof coating: 4 단계, 이미지 1개 중 1개
    • keep wiping up and down until a Grey/White coat starts forming, it will look similar to a widow smear.
  5. How to apply scratch-proof coating: 5 단계, 이미지 1개 중 1개
    • Leave to dry for 10 minuets and then buff off with a shammy (Chamois) Repeat the steps 3 times in total. The device can be used immediately. Keep clear of any objects that might scratch your screen until fully cured, in 24hrs.
    • Here is a coin scratching an iphone 5 LCD, watch and see what happens.
결론
다른 30명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Irish Jack
회원 가입일: 08/08/13
2,452 평판
안내서 1개를 작성함
4가이드 댓글
Dead product link
Jdwashere - 답글
Does this product/method work if you already have a couple of light scratches on the screen?
Thank you,
Gary
Gary Zehnpfennig - 답글
Does this product/method work if you already have a couple of light scratches on the screen.
Does this product/method work if you already have a couple of light scratches on the screen —
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 39
전체 시간: 17,041
