주요 콘텐츠로 건너뛰기
How to assign devices with a CSV file in Mosyle
  1. How to assign devices with a CSV file in Mosyle, Preparing your Data: 1 단계, 이미지 2개 중 1개 How to assign devices with a CSV file in Mosyle, Preparing your Data: 1 단계, 이미지 2개 중 2개
    • To start you'll need to get the CSV file from Mosyle's website. Go to My School > Device Assignment > Spreadsheet Assignment.
    • Under the section that says Download the template, and click Download CSV
  2. How to assign devices with a CSV file in Mosyle, Open the CSV: 2 단계, 이미지 1개 중 1개
    • Once the CSV file is downloaded open it in your spreadsheet program of choice.
    • The CSV will look something like this, but once we start entering user data you can delete the bottom most row.
  3. How to assign devices with a CSV file in Mosyle, Enter the user data: 3 단계, 이미지 1개 중 1개
    • Delete the cells that contain SERIAL_NUMBER_SAMPLE, USER_ID_SAMPLE, and CART_NAME.
    • Enter the device's serial number in the bottom row first column.
    • Enter either the User's ID or the Cart name in there respective column's. .
    • At least one of these need to be filled. Cart Name is optional as long as you have the User ID.
    • Once all your data is entered save the spreadsheet as a CSV file and upload the file to Mosyle by clicking Select File on the Spreadsheet Assignment page, and select your CSV file.
    • It will take Mosyle a bit to process your file. Any errors in user data will be reported once your file is finished uploading.
결론
While their are several different ways of assigning devices through Mosyle, CSV assignment is one of the easiest ways of assigning a large group of devices if you already have student information in a preexisting spreadsheet.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Jacob Mehnert
회원 가입일: 10/18/21
44,421 평판
안내서 51개를 작성함
iFanatics iFanatics 회원
Community
63 회원들
안내서 219개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 20
전체 시간: 1,311
