주요 콘텐츠로 건너뛰기
How to boot Intel Desktop Board D945PSN in Maintenance Mode
필요한 것
    • The beeping RAM Failure wouldn't let me boot since mainboard needs at least 128 mb of ram installed and with the "Agressive" ram setting it wouldn't see any of the RAM disks.
    • It beeped for hours without any real convetional (short battery pins or remove battery) fixes
  1. How to boot Intel Desktop Board D945PSN in Maintenance Mode, Locate CMOS Jumper and follow the instructions (adnotations on second pic): 2 단계, 이미지 2개 중 1개 How to boot Intel Desktop Board D945PSN in Maintenance Mode, Locate CMOS Jumper and follow the instructions (adnotations on second pic): 2 단계, 이미지 2개 중 2개
    • Switch jumper from normal position to "configure position" and start the system - it will go to maintenance mode.
  2. How to boot Intel Desktop Board D945PSN in Maintenance Mode: 3 단계, 이미지 2개 중 1개 How to boot Intel Desktop Board D945PSN in Maintenance Mode: 3 단계, 이미지 2개 중 2개
    • After you change the faulty settings, turn off and reinstall the jumper in Normal mode position as the Bios mentions.
    • After that see if the settings helped (i had to switch from aggressive mode to Automatic Ram management) and computer should boot up normally.
결론
That's the guide on how to reset CMOS or enter Maintenance mode on Intel mainboard D945PSN
다른 17명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Sebastian
회원 가입일: 01/29/15
672 평판
안내서 1개를 작성함
4가이드 댓글
Please I have a problem with an Intel desktop motherbord and the motherboard gives a sign that light is on the mainboard but I notice that it only given a light but not display on the screen
kenny - 답글
I don't know how to hook this dell desktop... An I pulled out a wire on the motherboard
D ON THA BANG-EL TnD Pro. - 답글
I keep getting that black screen (turn off and reinstall the jumper) despite having it in normal mode
Tonhs - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 18
지난 30일: 73
전체 시간: 15,464
