주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
How to boot into Recovery Mode on the iPhone 7 Plus
필요한 것
  1. How to boot into Recovery Mode on the iPhone 7 Plus, Press and Hold the Power and Volume Down Buttons: 1 단계, 이미지 1/1
    • Connect your iPhone 7 Plus to your Mac or PC with a Lightning to USB cable before you begin.
    • Resetting your iPhone will NOT remove iCloud Lock. You will be required to to enter your Apple ID and/or Password when you set your device up if you have iCloud Lock on.
    • Press and hold the Volume Down and Sleep/Wake buttons on your device.
    • Your screen should turn black, keep holding down the two buttons once it does.
    • The Recovery Mode Process is different than that of previous models of the iPhone due to the lack of a Physical Home Button.
  2. How to boot into Recovery Mode on the iPhone 7 Plus, Continue to Hold the Power and Volume Down Buttons: 2 단계, 이미지 1/1
    • After a few seconds the Apple Logo will appear, continue to hold down the Volume Down and Sleep/Wake Buttons until the screen turns black again.
    • If you let go of either button during this process the phone will boot into iOS and you will have to start again from Step 1.
  3. How to boot into Recovery Mode on the iPhone 7 Plus, Release the Buttons and Open iTunes: 3 단계, 이미지 1/1
    • After a few more seconds the Connect to iTunes screen will appear. Once it does, release the Volume Down and Sleep/Wake Buttons to avoid Force Restarting the device by accident.
    • On your Mac or PC, open up iTunes and you will be prompted with an error message stating that “There is a problem with the iPhone that requires it to be updated or restored.”
    • If you are updating your iPhone with a IPSW file, hold Shift while clicking the Update button. You will be prompted to select your IPSW file from apple.
    • This feature was removed from the Microsoft Store version of iTunes. You will need the version from Apple.com
    • Note that restoring your iPhone will Permanently Delete all your data including Apps, Music, Pictures, Videos, and Contacts. Make sure you backup your device before restoring it.
  4. How to boot into Recovery Mode on the iPhone 7 Plus, Booting Back to iOS: 4 단계, 이미지 1/2 How to boot into Recovery Mode on the iPhone 7 Plus, Booting Back to iOS: 4 단계, 이미지 2/2
    • This Step is Optional if you decide not to Update or Restore your Device.
    • To boot back into iOS, Press and Hold the Volume Down and Sleep/Wake Buttons until the screen turns black.
    • Once you see the Apple Logo, release both buttons and your iPhone will boot into iOS.
    • At this point you may Sync your iPhone with iTunes or disconnect the Lightning to USB cable and continue with your day.
결승점
다른 52명이 해당 안내서를 완성하였습니다.
Tecwizard
회원 가입일: 09/24/17
2,081 평판
안내서 2개 작성하였습니다
댓글 10개
Have been locked out of my Apple ID
hillibilly8 - 답글
Unfortunately Recovering your device will not remove iCloud Lock so you will need to recover your Apple ID through Apple
Tecwizard -
Hi, i forgot the apple id how to fix it?i want to make a new one how to do it thanks
Jumar - 답글
I have same problem i forgot the apple id how to fix it?i want to make a new one how to do it thanks
fa j - 답글
Hi have an iphone 7 it wont go into recovery mode n stuck at apple logo , n apple service providers said it has hardware issue so pls help me fixing the phone
Raghavendra - 답글
댓글 쓰기
조회 통계:
24 시간 전: 70
7일 전: 455
30일 전: 1,939
전체 시간: 247,521
