주요 콘텐츠로 건너뛰기
How to change Tool for DeepAccess
필요한 것
  1. How to change Tool for DeepAccess, How to change Tool for DeepAccess: 1 단계, 이미지 1개 중 1개
    • Prepare Tools and replacement parts.
  2. How to change Tool for DeepAccess, Remove wedge from transducer: 2 단계, 이미지 3개 중 1개 How to change Tool for DeepAccess, Remove wedge from transducer: 2 단계, 이미지 3개 중 2개 How to change Tool for DeepAccess, Remove wedge from transducer: 2 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Grab wegdge with tweezers
    • Loosen the screw. (while holding the wedge)
    • Get rid of the copper screw. To NOT use it more than once
  3. How to change Tool for DeepAccess, Place the new wedge in the transducer.: 3 단계, 이미지 3개 중 1개 How to change Tool for DeepAccess, Place the new wedge in the transducer.: 3 단계, 이미지 3개 중 2개 How to change Tool for DeepAccess, Place the new wedge in the transducer.: 3 단계, 이미지 3개 중 3개
    • Put the wedge in the tranducer from below.
    • Take care, that the Tool Top is flush with the Transducer surface
    • Correct Placement. Tool is flush with transducer.
    • Incorrect Placement. tool is too high.
  4. How to change Tool for DeepAccess, Fasten the copper screw: 4 단계, 이미지 2개 중 1개 How to change Tool for DeepAccess, Fasten the copper screw: 4 단계, 이미지 2개 중 2개
    • Fasten the screw lightly
    • Tighten the screw just so the wedge does not slip out of the tranducer.
    • in case of appliying too much torque. Use a new screw and get rid of the old one.
  5. How to change Tool for DeepAccess, Adjust wedge heigth with setting gauge: 5 단계, 이미지 3개 중 1개 How to change Tool for DeepAccess, Adjust wedge heigth with setting gauge: 5 단계, 이미지 3개 중 2개 How to change Tool for DeepAccess, Adjust wedge heigth with setting gauge: 5 단계, 이미지 3개 중 3개
    • Place gauge below Tool
    • Loosen the screw so the wedge slides onto the gauge Lever.
    • Lift the gauge up until in contact with the transducer horn.
    • Now the Tool-Top should be flush with the Transducer-Horn
    • Tighten the screw with the torque- wrench
    • Use Torque wrench with 18cN limitation
    • Use tweezers to push the wire down the wire hole, until it Ends some cm below the tool wedge.
    • Use scissors to cut the (contaminated) Wire down to a length of about 1cm below wedge end.
  6. How to change Tool for DeepAccess, Thread Wire through Wedge-hole: 7 단계, 이미지 3개 중 1개 How to change Tool for DeepAccess, Thread Wire through Wedge-hole: 7 단계, 이미지 3개 중 2개 How to change Tool for DeepAccess, Thread Wire through Wedge-hole: 7 단계, 이미지 3개 중 3개
    • Use tweezers to thread the wire through the hole at the end of the wedge.
    • Afet threading pull the wire some cm through the hole.
결론
작성자
3다른 기여자 명과 함께
Hans Panz
회원 가입일: 03/10/16
289 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 141
