주요 콘텐츠로 건너뛰기
How to change the grips on a golf club
필요한 것
  1. How to change the grips on a golf club, Grip: 1 단계, 이미지 2개 중 1개 How to change the grips on a golf club, Grip: 1 단계, 이미지 2개 중 2개
    • Tighten golf club on vice clamp. Align the golf club so that the club face is vertical.
    • Note: Make sure you place container underneath the grip to catch excess mineral spray in later steps.
  2. How to change the grips on a golf club: 2 단계, 이미지 2개 중 1개 How to change the grips on a golf club: 2 단계, 이미지 2개 중 2개
    • With the xacto knife cut the old grip off of the club.
    • Remove grip from club.
  3. How to change the grips on a golf club: 3 단계, 이미지 2개 중 1개 How to change the grips on a golf club: 3 단계, 이미지 2개 중 2개
    • Measure the amount of double-sided tape necessary to cover the area of your grip.
    • Place the tape on the club so that it is centered and an extra inch comes off the end of the club.
  4. How to change the grips on a golf club: 4 단계, 이미지 2개 중 1개 How to change the grips on a golf club: 4 단계, 이미지 2개 중 2개
    • Squirt mineral spirits on the tape.
    • Make sure you drench the tape in mineral spirits.
    • Note: it is safe to get mineral spirits on your skin, it is non-toxic.
  5. How to change the grips on a golf club: 5 단계, 이미지 3개 중 1개 How to change the grips on a golf club: 5 단계, 이미지 3개 중 2개 How to change the grips on a golf club: 5 단계, 이미지 3개 중 3개
    • While the tape still has mineral spray on it, quickly slide the grip all the way down.
  6. How to change the grips on a golf club: 6 단계, 이미지 1개 중 1개
    • Wait 1-2 hours for the mineral spray to dry.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Esteban Ortega
회원 가입일: 04/09/15
147 평판
안내서 1개를 작성함
Cal Poly, Team 30-2, Green Spring 2015 Cal Poly, Team 30-2, Green Spring 2015 회원
CPSU-GREEN-S15S30G2
4 회원들
안내서 4개를 작성함
댓글 한 개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 18
전체 시간: 1,176
