주요 콘텐츠로 건너뛰기
How to change the oil and replace the oil filter in a Suzuki DR650 SE
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
    • Remove oil drain plug and let all oil drain from the engine. Now remove oil filter cover and take out the old filter.
    • Clean out the oil filter reservoir and put in the new oil filter. Replace the filter cover and screw back on tightly. Also replace the oil drain plug.
    • Remove the oil cap and use your funnel to pour in the oil. Watch the glass oil fill level to see how much has been put in. Once full, put the oil cap back on. (2.5 quarts with oil filter, 2.4 w/o filter.)
    • Now that everything is replaced, start the bike up to make sure you have no leaks and see that everything is running smoothly.
결론
Detailed guide pictures will be added later. Until then, here is a video guide: http://www.youtube.com/watch?v=GHj3GjUlx...
다른 2명이 해당 안내서를 완성하였습니다.
Ryan
회원 가입일: 10/11/14
161 평판
안내서 1개 작성함
USF Tampa, Team 1-18, Donnelly Fall 2014 USF Tampa, Team 1-18, Donnelly Fall 2014 회원
USFT-DONNELLY-F14S1G18
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 195
