소개
In this guide, you will be shown how to change the oil in the motorcycle along with changing the oil filter. Once you know the steps and see where you will be working, it is not hard to complete the oil changing task. Completing the oil change should take approximately 20 minutes.
필요한 것
Remove oil drain plug and let all oil drain from the engine. Now remove oil filter cover and take out the old filter.
Detailed guide pictures will be added later. Until then, here is a video guide: http://www.youtube.com/watch?v=GHj3GjUlx...
다른 2명이 해당 안내서를 완성하였습니다.
