주요 콘텐츠로 건너뛰기
How to check Fujifilm FinePix S8200 for loose LCD connection
필요한 것
  1. How to check Fujifilm FinePix S8200 for loose LCD connection, Batteries: 1 단계, 이미지 1개 중 1개
    • Turn the camera upside down so you can access the battery chamber.
    • Make sure that the camera is powered off before opening the battery chamber. Not doing so could damage your memory card.
  2. How to check Fujifilm FinePix S8200 for loose LCD connection: 2 단계, 이미지 1개 중 1개
    • Push the battery chamber latch in the direction of the front of the camera. Keeping tension on the latch, slide the battery chamber cover toward the outside of the camera, opening the battery chamber.
  3. How to check Fujifilm FinePix S8200 for loose LCD connection: 3 단계, 이미지 1개 중 1개
    • With the battery chamber open, remove the old batteries.
    • When replacing the batteries, remember that the battery orientation is shown by the + and - marks. Each mark indicates which side of the battery faces up in the chamber.
  4. How to check Fujifilm FinePix S8200 for loose LCD connection, Rear Housing Cover: 4 단계, 이미지 3개 중 1개 How to check Fujifilm FinePix S8200 for loose LCD connection, Rear Housing Cover: 4 단계, 이미지 3개 중 2개 How to check Fujifilm FinePix S8200 for loose LCD connection, Rear Housing Cover: 4 단계, 이미지 3개 중 3개
    • Remove the 4mm JIS #00 screws from the sides and bottom of the camera.
  5. How to check Fujifilm FinePix S8200 for loose LCD connection: 5 단계, 이미지 3개 중 1개 How to check Fujifilm FinePix S8200 for loose LCD connection: 5 단계, 이미지 3개 중 2개 How to check Fujifilm FinePix S8200 for loose LCD connection: 5 단계, 이미지 3개 중 3개
    • Carefully pry away the rear housing cover with the plastic opening tool.
  6. How to check Fujifilm FinePix S8200 for loose LCD connection: 6 단계, 이미지 1개 중 1개
    • Remove the rear housing cover by carefully pulling it away from the camera.
  7. How to check Fujifilm FinePix S8200 for loose LCD connection, How to check Fujifilm FinePix S8200 for loose LCD connection: 7 단계, 이미지 1개 중 1개
    • Fold back the LCD screen and check that the cable coming from the screen is securely fastened to the motherboard.
  8. How to check Fujifilm FinePix S8200 for loose LCD connection: 8 단계, 이미지 1개 중 1개
    • Fold the LCD screen back into the proper position.
결론
작성자
3다른 기여자 명과 함께
Joseph Kelley
회원 가입일: 01/15/15
228 평판
안내서 2개를 작성함
USF Tampa, Team 7-1, Remmell Winter 2015 USF Tampa, Team 7-1, Remmell Winter 2015 회원
USFT-REMMELL-W15S7G1
4 회원들
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 821
