주요 콘텐츠로 건너뛰기
How to check Sony Ericsson W200i battery voltage
필요한 것
  1. How to check Sony Ericsson W200i battery voltage, Disassembling Sony Ericsson W200i Battery: 1 단계, 이미지 1/2 How to check Sony Ericsson W200i battery voltage, Disassembling Sony Ericsson W200i Battery: 1 단계, 이미지 2/2
    • Slide the battery cover up and off the phone.
  2. How to check Sony Ericsson W200i battery voltage: 2 단계, 이미지 1/2 How to check Sony Ericsson W200i battery voltage: 2 단계, 이미지 2/2
    • Pop the battery out of its slot by lifting it up.
  3. How to check Sony Ericsson W200i battery voltage, How to check Sony Ericsson W200i battery voltage: 3 단계, 이미지 1/2 How to check Sony Ericsson W200i battery voltage, How to check Sony Ericsson W200i battery voltage: 3 단계, 이미지 2/2
    • Plug the red probe into the center jack, the black probe into the bottom jack, and turn the range selector switch to 20 DCV.
    • Turn the multimeter on.
  4. How to check Sony Ericsson W200i battery voltage: 4 단계, 이미지 1/1
    • Touch the red probe to the indicated positive side and the black probe to the indicated negative side.
    • Replace the battery if the voltage reads below 2.5 volts.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Ryan Waltman
회원 가입일: 01/14/11
111 평판
안내서 1개 작성함
Cal Poly, Team 14-10, Forte Winter 2011 Cal Poly, Team 14-10, Forte Winter 2011 회원
CPSU-FORTE-W11S14G10
5 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 5,396
