주요 콘텐츠로 건너뛰기
How to check if iPod HDD is fine.
  1. How to check if iPod HDD is fine., Restart and boot your iPod to recovery mode.: 1 단계, 이미지 2개 중 1개 How to check if iPod HDD is fine., Restart and boot your iPod to recovery mode.: 1 단계, 이미지 2개 중 2개
    • Hold down the SELECT (middle) button and the MENU button to restart your iPod.
    • Then hold down the select (middle) button and the previous track button.
  2. How to check if iPod HDD is fine., Operating the recovery menu.: 2 단계, 이미지 3개 중 1개 How to check if iPod HDD is fine., Operating the recovery menu.: 2 단계, 이미지 3개 중 2개 How to check if iPod HDD is fine., Operating the recovery menu.: 2 단계, 이미지 3개 중 3개
    • Scroll your click wheel to IO (select with select)
    • Then Hard Drive
  3. How to check if iPod HDD is fine., Scanning the HD!: 3 단계, 이미지 2개 중 1개 How to check if iPod HDD is fine., Scanning the HD!: 3 단계, 이미지 2개 중 2개
    • Lastly, HDScan
    • Scan takes a while, wait.
  4. How to check if iPod HDD is fine., Conclusion.: 4 단계, 이미지 1개 중 1개
    • If you get a message "11ror!" your HDD is toast. RIP HDD ;(
    • Else, your HDD is fine!
결론
To restart your iPod hold down the select (middle) button and the menu button.
다른 22명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
windowsio ROBLOX And More
회원 가입일: 03/18/18
790 평판
안내서 1개를 작성함
6가이드 댓글
After holding down select and previous track buttons in Step 1, my iPod always shows a warning sign with www.apple.com/support/ipod Is there a way to get around this?
andrew.zellman - 답글
Dead hard drive then.
Cody Baxter -
If it's a red x then yes, your hard drive is dead.
To be completely honest reading this guide I did a really bad job of being professional. Sorry for the cringe guys.
windowsio ROBLOX And More -
I am able to get to the scanner, but my iPod boot loops before its able to finish. What would that mean?
CreeperDoolie - 답글
I've just ordered an iFlash for my iPod Classic and wondered if the hard drive in my iPod was getting bad, but this helped out a ton! I may even keep using my iPod until the drive dies. The menu is really useful and confirmed that I don't need to replace the battery either! Thanks a bunch for this guide!
Metabera - 답글
댓글 쓰기
조회 통계:
지난 24시간: 19
지난 7일: 74
지난 30일: 408
전체 시간: 27,704
