주요 콘텐츠로 건너뛰기
How to check if iPod HDD is fine.
  1. How to check if iPod HDD is fine., Restart and boot your iPod to recovery mode.: 1 단계, 이미지 1/2 How to check if iPod HDD is fine., Restart and boot your iPod to recovery mode.: 1 단계, 이미지 2/2
    • Hold down the SELECT (middle) button and the MENU button to restart your iPod.
    • Then hold down the select (middle) button and the previous track button.
  2. How to check if iPod HDD is fine., Operating the recovery menu.: 2 단계, 이미지 1/3 How to check if iPod HDD is fine., Operating the recovery menu.: 2 단계, 이미지 2/3 How to check if iPod HDD is fine., Operating the recovery menu.: 2 단계, 이미지 3/3
    • Scroll your click wheel to IO (select with select)
    • Then Hard Drive
  3. How to check if iPod HDD is fine., Scanning the HD!: 3 단계, 이미지 1/2 How to check if iPod HDD is fine., Scanning the HD!: 3 단계, 이미지 2/2
    • Lastly, HDScan
    • Scan takes a while, wait.
  4. How to check if iPod HDD is fine., Conclusion.: 4 단계, 이미지 1/1
    • If you get a message "11ror!" your HDD is toast. RIP HDD ;(
    • Else, your HDD is fine!
결론
To restart your iPod hold down the select (middle) button and the menu button.
다른 19명이 해당 안내서를 완성하였습니다.
windowsio ROBLOX And More
회원 가입일: 03/18/18
709 평판
안내서 1개 작성함
댓글 5개
After holding down select and previous track buttons in Step 1, my iPod always shows a warning sign with www.apple.com/support/ipod Is there a way to get around this?
andrew.zellman - 답글
Dead hard drive then.
Cody Baxter -
If it's a red x then yes, your hard drive is dead.
To be completely honest reading this guide I did a really bad job of being professional. Sorry for the cringe guys.
windowsio ROBLOX And More -
I am able to get to the scanner, but my iPod boot loops before its able to finish. What would that mean?
CreeperDoolie - 답글
I've just ordered an iFlash for my iPod Classic and wondered if the hard drive in my iPod was getting bad, but this helped out a ton! I may even keep using my iPod until the drive dies. The menu is really useful and confirmed that I don't need to replace the battery either! Thanks a bunch for this guide!
Metabera - 답글
댓글 쓰기
조회 통계:
24 시간 전: 24
7일 전: 141
30일 전: 591
전체 시간: 15,770
