주요 콘텐츠로 건너뛰기
How to check the oil level in your Mercedes W123
필요한 것
  1. How to check the oil level in your Mercedes W123, How to check the oil level in your Mercedes W123: 1 단계, 이미지 1개 중 1개
    • Oil level is checked using the engine oil dip stick. It is located on the right side of the engine when facing it from the front of the car.
    • The W123 used in this guide is a diesel car so the dip stick is located near the large secondary fuel filter and the injector hard lines. The items around your dip stick may look different.
  2. How to check the oil level in your Mercedes W123: 2 단계, 이미지 1개 중 1개
    • Pull the dipstick up and out towards the hood of the car.
    • Have a shop rag ready to catch any drips from the tip of the dip stick as it comes out of the tube it resides in
  3. How to check the oil level in your Mercedes W123: 3 단계, 이미지 1개 중 1개
    • The dip stick will come out with oil covering the tip. On a diesel engine it is normal for the oil to be dark black; the oil is designed to hold the diesel soot in suspension. If this were a gas engine it would definitely be time to change the oil just by the visual appearance of it! On a diesel you'll have to go more by age or mileage.
    • The oil level should fall somewhere between the notches on the tip of the stick. The notches mean:
    • Low - add oil
    • Full
    • If oil is at or below the Low notch add oil slowly, checking the level occasionally, until it reaches the Full notch.
    • Never overfill your engine with oil! Especially on a diesel. It can be pulled in to the cylinders and it could lead to a run-away engine.
  4. How to check the oil level in your Mercedes W123: 4 단계, 이미지 1개 중 1개
    • Wipe the dipstick clean with a shop towel or other clean rag
    • To be sure of the oil level check it a second time after wiping it clean as outlined in steps 2 and 3.
  5. How to check the oil level in your Mercedes W123: 5 단계, 이미지 1개 중 1개
    • Return the dipstick to the tube when completed and be sure to push it all the way in until it seats properly in the tip of the tube.
결론
다른 14명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Nicolas Siemsen
회원 가입일: 12/06/13
40,257 평판
안내서 79개를 작성함
Master Techs Master Techs 회원
Community
329 회원들
안내서 1,452개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 64
지난 30일: 264
전체 시간: 23,391
