이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Oil level is checked using the engine oil dip stick. It is located on the right side of the engine when facing it from the front of the car.
The W123 used in this guide is a diesel car so the dip stick is located near the large secondary fuel filter and the injector hard lines. The items around your dip stick may look different.
Pull the dipstick up and out towards the hood of the car.
Have a shop rag ready to catch any drips from the tip of the dip stick as it comes out of the tube it resides in
The dip stick will come out with oil covering the tip. On a diesel engine it is normal for the oil to be dark black; the oil is designed to hold the diesel soot in suspension. If this were a gas engine it would definitely be time to change the oil just by the visual appearance of it! On a diesel you'll have to go more by age or mileage.
The oil level should fall somewhere between the notches on the tip of the stick. The notches mean:
Low - add oil
Full
If oil is at or below the Low notch add oil slowly, checking the level occasionally, until it reaches the Full notch.
Wipe the dipstick clean with a shop towel or other clean rag
To be sure of the oil level check it a second time after wiping it clean as outlined in steps 2 and 3.
Return the dipstick to the tube when completed and be sure to push it all the way in until it seats properly in the tip of the tube.
다른 14명이 해당 안내서를 완성하였습니다.
