주요 콘텐츠로 건너뛰기
How to clean Apple EarPods
필요한 것
  1. How to clean Apple EarPods, Apple EarPods cleaning: 1 단계, 이미지 1/1
    • If your EarPods are dirty with dust or wax, or anything else on the ear pieces, follow these steps to clean them.
  2. How to clean Apple EarPods: 2 단계, 이미지 1/2 How to clean Apple EarPods: 2 단계, 이미지 2/2
    • Use a toothpick to rub all the holes in the earphone
    • Don't use a pencil, it lets waste or any other metal tool, you can puncture the earpod and ruin it.
  3. How to clean Apple EarPods: 3 단계, 이미지 1/2 How to clean Apple EarPods: 3 단계, 이미지 2/2
    • Repeat the process for the other EarPod
  4. How to clean Apple EarPods: 4 단계, 이미지 1/2 How to clean Apple EarPods: 4 단계, 이미지 2/2
    • Use isopropyl alcohol (rubbing alcohol) to clean the exterior of the EarPod
    • Ignore the fact that the alcohol is in the Earpods' case
  5. How to clean Apple EarPods: 5 단계, 이미지 1/2 How to clean Apple EarPods: 5 단계, 이미지 2/2
    • Don't submerge the EarPods in the alcohol. If the alcohol enters the interior of the Earpod, it will damage the speaker.
  6. How to clean Apple EarPods: 6 단계, 이미지 1/1
    • Let the EarPods dry for at least 10 minutes before using
    • Let the Earpods dry by itself, if you use a fan, a hair dryer, or anything else, you could generate corrosion inside and that will ruin it
결론
Remember to dry your Earpods for 10 minutes.
다른 85명이 해당 안내서를 완성하였습니다.
jimenezser
회원 가입일: 08/29/12
3,848 평판
안내서 4개 작성하였습니다
댓글 31개
Best way is clean the larger part with a earbud. The smaller doesnt make that much sound. Blow air onto the larger part after cleaning.
jaidityayadav - 답글
I use a cotton swab (q-tip). First a dry one, then I blow into all openings, next I use a damp (not dripping) q-tip (alcohol, saliva) to remove remaining wax, dirt. There are four opening on each earbud. I clean them all.
allisonbridges1 - 답글
With saliva? You &&^&^$ disgusting.
Pixel Shibe -
GROSS Saliva? yuck
adrienne adams -
what the &&^& is wrong with you
fisheruwu edits -
댓글 쓰기
조회 통계:
24 시간 전: 12
7일 전: 61
30일 전: 286
전체 시간: 407,662
