주요 콘텐츠로 건너뛰기
How to clean Apple Mighty Mouse scroll ball
필요한 것
  1. How to clean Apple Mighty Mouse scroll ball, How to clean Apple Mighty Mouse scroll ball: 1 단계, 이미지 1개 중 1개
    • Before you continue, turn off the mouse using the slide switch underneath the mouse.
    • Before disassembling the mouse, first try scrubbing the mouse ball with a toothbrush and isopropyl alcohol. Be sure to get the bristles between the ball and the housing as this will help remove dirt and dust that is clogging the rollers inside.
    • You can also try blowing into the "ball hole" with a can of compressed air.
결론
Allow the mouse to dry for a few minutes before turning it back on to test it.
다른 52명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
bushing
회원 가입일: 04/23/10
10,363 평판
안내서 13개를 작성함
댓글 15개
In order to clean perfectly the scrollball, you can hold the mouse upside down, and roll very quickly the scrollball on a white A4 papersheet (As if you wanted to colour the papersheet with the scrollball). Normally, you'll see some grey stripe of dust on the paper sheet!
Ludal - 답글
Wow - Ludal's advice actually worked! I'm amazed. Paper -- just a plain sheet of paper.
Marvin Miller -
I can't believe I just found this post in 2015, gotta say thank you for saving $53 bucks!
Junior Harrison -
I actually did both things but I used one of those wipes for eyeglasses which have alcohol in them after rubbing it on paper. Worked great.
Brian Kemian -
Thanks a loit. Even in 2020 it helped ;-)
Robert Reichel -
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 29
지난 30일: 92
전체 시간: 45,007
