주요 콘텐츠로 건너뛰기
How to clean Canon PowerShot A550 buttons
필요한 것
  1. How to clean Canon PowerShot A550 buttons, Front and Back Covers: 1 단계, 이미지 1/3 How to clean Canon PowerShot A550 buttons, Front and Back Covers: 1 단계, 이미지 2/3 How to clean Canon PowerShot A550 buttons, Front and Back Covers: 1 단계, 이미지 3/3
    • Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
    • There are 2 screws on the left side (when looking at the front of the camera).
    • There are 3 screws on the bottom
    • There is 1 screw on the right side
  2. How to clean Canon PowerShot A550 buttons: 2 단계, 이미지 1/1
    • Turn to the bottom of the camera.
    • Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
  3. How to clean Canon PowerShot A550 buttons: 3 단계, 이미지 1/1
    • This is what the SD card/battery compartment looks like when opened.
    • Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
  4. How to clean Canon PowerShot A550 buttons: 4 단계, 이미지 1/2 How to clean Canon PowerShot A550 buttons: 4 단계, 이미지 2/2
    • Gently remove the front cover away from the camera body.
    • Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
  5. How to clean Canon PowerShot A550 buttons: 5 단계, 이미지 1/1
    • The camera should look like this once the front cover is removed.
  6. How to clean Canon PowerShot A550 buttons: 6 단계, 이미지 1/3 How to clean Canon PowerShot A550 buttons: 6 단계, 이미지 2/3 How to clean Canon PowerShot A550 buttons: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Start from the battery compartment and remove the back cover.
    • Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
    • Remove the connecting ribbon from the body of the camera using a pair of tweezers.
  7. How to clean Canon PowerShot A550 buttons: 7 단계, 이미지 1/1
    • Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
  8. How to clean Canon PowerShot A550 buttons, How to clean Canon PowerShot A550 buttons: 8 단계, 이미지 1/1
    • Turn to the back of the camera body. Rub the function keys and surrounding area with a clean cloth dipped in isopropyl alcohol.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Shaelyn Thomas
회원 가입일: 04/19/11
332 평판
안내서 4개 작성하였습니다
Cal Poly, Team 8-6, Regan Spring 2011 Cal Poly, Team 8-6, Regan Spring 2011 회원
CPSU-REGAN-S11S8G6
4 회원들
안내서 22개 작성하였습니다
댓글 한 개
new Battery in side & massages is Battery low why?
Rupesh Jamsandekar - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 22
전체 시간: 1,966
