주요 콘텐츠로 건너뛰기
How to clean Game Boy Advance buttons
필요한 것
  1. How to clean Game Boy Advance buttons, How to clean Game Boy Advance buttons: 1 단계, 이미지 1/2 How to clean Game Boy Advance buttons, How to clean Game Boy Advance buttons: 1 단계, 이미지 2/2
    • Use a slightly damp toothbrush to scrape in between the desired sticky buttons. You can also use a bit of isopropyl alcohol.
    • Make sure toothbrush is not to the point of dripping water when scraping.
  2. How to clean Game Boy Advance buttons: 2 단계, 이미지 1/1
    • Dry with a cloth after the sticky residue is removed.
결승점
다른 9명이 해당 안내서를 완성하였습니다.
Adam
회원 가입일: 01/20/10
815 평판
안내서 5개 작성하였습니다
Cal Poly, Team 16-29, Maness Winter 2010 Cal Poly, Team 16-29, Maness Winter 2010 회원
CPSU-MANESS-W10S16G29
5 회원들
안내서 61개 작성하였습니다
댓글 3개
I just used this method to clean sticky buttons on a wireless Xbox 360 controller. The Back, Xbox Guide, Start, X, Y, B, and A buttons were all sticky and unresponsive.
I removed the battery pack and followed the steps, and it worked like a charm. All of the buttons work just fine now except for the Xbox Guide button, which isn't really a big deal anyway.
This method works great. Thanks for making this guide, Adam.
Jeff Laxson - 답글
Wow. I thought I was going to have to buy a new Wii U Pro Controller, but this fixed my sticky B button. So simple. Thanks for saving me $50, friend.
Trevor Babcock - 답글
my d-pad needs cleaning, help?
Trace Ruby - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 19
30일 전: 66
전체 시간: 27,374
