주요 콘텐츠로 건너뛰기
How to clean Motorola T720c screen and LCD
필요한 것
  1. How to clean Motorola T720c screen and LCD, How to clean Motorola T720c screen and LCD: 1 단계, 이미지 1개 중 1개
    • On the door's bottom edge, locate the gap between the external and internal screen covers.
    • Using a spudger (not shown), gently pry apart the external and internal covers until the sides start to separate.
    • Continue working your way along the edges of the phone, alternating sides, until the external cover can be easily removed.
  2. How to clean Motorola T720c screen and LCD: 2 단계, 이미지 2개 중 1개 How to clean Motorola T720c screen and LCD: 2 단계, 이미지 2개 중 2개
    • On the display housing, locate and unscrew the four corner T6 Torx screws connecting the housing and the internal cover.
  3. How to clean Motorola T720c screen and LCD: 3 단계, 이미지 2개 중 1개 How to clean Motorola T720c screen and LCD: 3 단계, 이미지 2개 중 2개
    • The fragile wire strip connecting the display housing to the circuit board is located on the left side of the inner hinge.
    • Locate the gap between the display housing and internal cover, in the same manner you would flip open the phone, use your finger (not shown) to lift the housing from the cover and set it down.
  4. How to clean Motorola T720c screen and LCD: 4 단계, 이미지 1개 중 1개
    • Using a lens cloth, wipe away any dust or debris from the display or screens.
결론
작성자
7다른 기여자 명과 함께
Amy
회원 가입일: 10/15/12
1 평판
안내서 4개를 작성함
University of Maine, Team 1-4, Diaz Fall 2012 University of Maine, Team 1-4, Diaz Fall 2012 회원
UMAINE-DIAZ-F12S1G4
5 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 465
