주요 콘텐츠로 건너뛰기
How to clean Nikon N2000 (F301) battery corrosion
필요한 것
    • In this guide we will be referring to 'left'and 'right' as though the camera's front (the part that says Nikon) facing you.
    • Use a quarter to twist open the one large screw on the bottom case. (No picture available.)
  1. How to clean Nikon N2000 (F301) battery corrosion: 2 단계, 이미지 1/1
    • Pull up on the tab to remove the batteries.
    • Note: The batteries will probably fall out of their holder.
  2. How to clean Nikon N2000 (F301) battery corrosion: 3 단계, 이미지 1/1
    • Your camera should look something like this.
    • Clean the marked areas with a cotton swab soaked in CLR or vinegar.
  3. How to clean Nikon N2000 (F301) battery corrosion: 4 단계, 이미지 1/1
    • Corrosion appears as the bluish build-up you see in this picture. Scrub with a cotton swab until it has visibly decreased.
  4. How to clean Nikon N2000 (F301) battery corrosion: 5 단계, 이미지 1/1
    • All cleaned up!
결론
Reinsert the batteries by following the instructions backwards. If it's still not getting power, head over to our battery compartment replacement guide. Note: It may be tough to find replacement parts.
다른 3명이 해당 안내서를 완성하였습니다.
Zachary Phillips
회원 가입일: 04/08/11
247 평판
안내서 5개 작성하였습니다
Cal Poly, Team 25-26, Garner Spring 2011 Cal Poly, Team 25-26, Garner Spring 2011 회원
CPSU-GARNER-S11S25G26
3 회원들
안내서 12개 작성하였습니다
댓글 2개
Wow it working thanks for assisting me. I used vinegar to clean my camera so it working now
lazarusmolai - 답글
Thumb down! Step 5 says, “All cleaned up!” But the picture shows much corrosion still present. Asking for further problems! Look up: "Nintendo Gameboy Pocket Shell-Side Battery Terminal CorrosionRemoval” for tips how to do it more thoroughly.
Wolf Naegeli - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 13
30일 전: 69
전체 시간: 15,652
