주요 콘텐츠로 건너뛰기
소개
Corrosion usually occurs in the battery compartment. It appears as a light blue coating on any metal components and prevents power from flowing in the camera.
부품
지정된 부품이 없습니다.
    • In this guide we will be referring to 'left'and 'right' as though the camera's front (the part that says Nikon) facing you.
    • Use a quarter to twist open the one large screw on the bottom case. (No picture available.)
  1. Pull up on the tab to remove the batteries.
    • Pull up on the tab to remove the batteries.
    • Note: The batteries will probably fall out of their holder.
  2. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    지금 장보기
    iPhone X Fix Kits
    지금 장보기
  3. Your camera should look something like this.
    • Your camera should look something like this.
    • Clean the marked areas with a cotton swab soaked in CLR or vinegar.
  4. Corrosion appears as the bluish build-up you see in this picture. Scrub with a cotton swab until it has visibly decreased.
    • Corrosion appears as the bluish build-up you see in this picture. Scrub with a cotton swab until it has visibly decreased.
  5. All cleaned up!
    • All cleaned up!
결론
Reinsert the batteries by following the instructions backwards. If it's still not getting power, head over to our battery compartment replacement guide. Note: It may be tough to find replacement parts.
다른 3명이 해당 안내서를 완성하였습니다.
Zachary Phillips
회원 가입일: 2011년 04월 08일
205 평판
안내서 5개 작성하였습니다
Cal Poly, Team 25-26, Garner Spring 2011 Cal Poly, Team 25-26, Garner Spring 2011 회원
CPSU-GARNER-S11S25G26
3 회원들
안내서 7개 작성하였습니다
Wow it working thanks for assisting me. I used vinegar to clean my camera so it working now
lazarusmolai - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 47
전체 시간: 12,196
